Re: Can H beam rods be rebuilt?
[Re: Eric]
#2540385
08/23/18 12:04 PM
08/23/18 12:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine were new H-beam rods but I changed the balance on the crank so I had to tweak the rod balance and the small end.. they had been on the dyno for 10 minutes
[Re: Digger73]
#2540516
08/23/18 05:04 PM
08/23/18 05:04 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Thanks everyone for the advise and information. The flip side of this is that the crank will also need some attention. So, by the time I buy new rods, engine bearings, crank work and re balance. I am most of the way to a new 440 source stroker kit. If I go the new kit route I can opt for more compression and more stroke. Just looking for the best option at this time.
Thanks all,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: sgcuda]
#2540529
08/23/18 05:50 PM
08/23/18 05:50 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If the rod discolored, I would replace it.
[Re: Digger73]
#2540557
08/23/18 06:42 PM
08/23/18 06:42 PM
Digger73
Portland, Oregon
When I get home tonight I will get some pictures down loaded of the rods and the bearings.
Digger73 (Mike)
[Re: Digger73]
#2540650
08/23/18 11:12 PM
08/23/18 11:12 PM
Digger73
Portland, Oregon
Here are the pictures of what my rods look like now.
Digger73 (Mike)
[Re: Digger73]
#2540663
08/23/18 11:40 PM
08/23/18 11:40 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Heck that didn’t get very hot from those pictures. I would torque it together and check it with a set of mics or a bore gauge.
[Re: Digger73]
#2540674
08/23/18 11:58 PM
08/23/18 11:58 PM
MR_P_BODY
I dont like that one rod.. has blue about a quarter of the rod width.. make sure you check that rod out closely
[Re: Digger73]
#2540771
08/24/18 08:55 AM
08/24/18 08:55 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Definitely, the start of something bad. But, it looks like you caught it pretty early. You should have it checked for stretch. Those rods can be resized on the big end, but I don't know if the heat that caused the blue streak is significant enough to warrant replacement. Check with your machinist. 1 rod isn't a significant expense to save the motor. More importantly, I think I would be having the crank magnafluxed at this point.
