AlumaJ8 build #2518320
07/06/18 10:41 AM
07/06/18 10:41 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I think I have enough parts to start a build thread. I sold my Willys MB and I am building an LJ length CJ to replace it. It will be kept low and on 40s. The body will be from Aqualu when I finally order it, haha.
Re: AlumaJ8 build [Re: Defbob] #2518321
07/06/18 10:48 AM
07/06/18 10:48 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
The first part I got for the build was a ‘12 Ram 3500 steering box. This is funny because the first part I had for my Willys was a steering box, then a pair of axles. Which is the same situation here... I got a pair of ‘09 Superduty axles. I later decided the pumpkin location was not ideal for my situation. I ordered a custom housing from ECGS to work with my Reid Superduty knuckles and retain the stock Superduty width.
I also got a pair of Savvy LED tail lights
Re: AlumaJ8 build [Re: Defbob] #2518326
07/06/18 10:55 AM
07/06/18 10:55 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Re: AlumaJ8 build [Re: Defbob] #2518331
07/06/18 11:02 AM
07/06/18 11:02 AM
Guitar Jones Offline
I must say you do build some awesome stuff, nice work. You are very talented. I however cant imagine what you spend on that stuff or where you find things like a custom diff housing for a SD.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: AlumaJ8 build [Re: Guitar Jones] #2518347
07/06/18 11:44 AM
07/06/18 11:44 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
There had been a suspicion on Pirate4x4 whether the Spicer Ultimate 60 balljoint setup was based on the production F350. Then Spicer released their “builder program” and you could buy the inner Cs loose. No one wanted to order a set and test it out. So I did. I measure everything and it matches the oem inner C. Takes the same balljoints, same spread and same inclination angle.
By using the Superduty outers and not the standard kingpin stuff... I get to use 1550 u joints.
Re: AlumaJ8 build [Re: Defbob] #2523198
07/17/18 05:56 PM
07/17/18 05:56 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
My Genright YJ Crawler Comp 23 gallon gas tank showed up.
Re: AlumaJ8 build [Re: Defbob] #2525238
07/22/18 09:44 AM
07/22/18 09:44 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
popcorn
Re: AlumaJ8 build [Re: redraptor] #2538475
08/19/18 11:20 AM
08/19/18 11:20 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I picked up a pair of surplus Bussmann 3100 relay modules. And my tires showed up. Ended up going with 42" Pitbull Rockers since they had a 50% sale the other week. Compared the tires to Tom's wimpy 35s...
Re: AlumaJ8 build [Re: Defbob] #2538476
08/19/18 11:23 AM
08/19/18 11:23 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I got my custom length 1550 joint axle shafts from Branik
Re: AlumaJ8 build [Re: Defbob] #2538477
08/19/18 11:29 AM
08/19/18 11:29 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I got my Spicer master install kit, Spicer Super60 10" 5.38 ring gear, Spicer ball joints, and Ball joint cams from DowntoFab
Re: AlumaJ8 build [Re: Defbob] #2544559
09/02/18 11:43 AM
09/02/18 11:43 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Installed the balljoints in one of the knuckles to mock up on the housing. I wanted to double check that the everything lined up correctly.
Re: AlumaJ8 build [Re: Defbob] #2544856
09/03/18 12:02 AM
09/03/18 12:02 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Close enough. What's next???
Re: AlumaJ8 build [Re: Defbob] #2544912
09/03/18 02:19 AM
09/03/18 02:19 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What’s going to power your new beast?
Re: AlumaJ8 build [Re: WO23Coronet] #2544954
09/03/18 08:55 AM
09/03/18 08:55 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
6.0l, 4L80E, Atlas 3.0
