Stud between master cylinder and booster #2537506
08/17/18 07:04 AM
08/17/18 07:04 AM
Germany
JS23U Offline OP
JS23U  Offline OP
Germany
Hi,
can the studs that mount the master cylinder to the power booster be serviced? One thread doesn't look good. Car in question is a 1971 Charger with a Midland Ross booster.
Where can I find a stud (or a set of four...)?
Re: Stud between master cylinder and booster [Re: JS23U] #2537607
08/17/18 01:11 PM
08/17/18 01:11 PM
will the booster halves seperate so you can access the bolts or is it factory crimped & or does it look like a rethreading die would clean the bolt?
Re: Stud between master cylinder and booster [Re: JS23U] #2537753
08/17/18 05:52 PM
08/17/18 05:52 PM
Germany
JS23U Offline OP
JS23U  Offline OP
Germany
My Midland booster can be disassembled. The thread on the stud is stripped, not possible to recut. I'd like to change the stud which looks to be pressed in. If I could find a correct one.
The pic is just for reference, found somewhere on the net. I wished mine would look like that...
Re: Stud between master cylinder and booster [Re: JS23U] #2538346
08/19/18 12:34 AM
08/19/18 12:34 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You might want to contact Booster Dewey to see if it be pressed out.
If you PM me next weekend I can check on the boosters I have apart, but contacting Dewey might be faster.
Once you have the booster apart you can replate it and it will look like the one in the picture. The hard part might be finding the long bolt that clamps it together because factory bent that bolt in the process and it has to be cut off.
