delay box starting out setting #2537680
08/17/18 03:10 PM
08/17/18 03:10 PM
st.louis,mo.
dart games Offline OP
st.louis,mo.
what would be a good delay box starting out number,i know a lot plays into it,where you put the car in the beams,tire size,tire pressure,rear end ratio,rear tire size,how you see the tree,left lane or right lane,
Re: delay box starting out setting [Re: dart games] #2537696
08/17/18 03:48 PM
08/17/18 03:48 PM
Kentucky
3
301v Offline
301v  Offline
Kentucky
How fast is the car and the 60ft? Hard to guess cause everyone reacts different and not every starting line has the same roll out but might be able to get ya somewhat in the ballpark.
Re: delay box starting out setting [Re: dart games] #2537697
08/17/18 03:49 PM
08/17/18 03:49 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A lot goes into this but with my car doing 1.25-1.27 sixty foot times I'm set at 1.055-1.065 but everyone car, tire size, and suspension is different. Test n tune is your friend for getting it zero'd in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: delay box starting out setting [Re: dart games] #2537705
08/17/18 03:57 PM
08/17/18 03:57 PM
gregsdart Offline
gregsdart  Offline
I need 1.10 in mine, torqueflite, 1.26 60 ft, 24.5 tall front runners, leave at 5200 off a 6200 stall, 8.90 ETaverage, 3065 lbs, 33 x15 slicks. car weighs 3065.
Re: delay box starting out setting [Re: dart games] #2537706
08/17/18 03:58 PM
08/17/18 03:58 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Set it at one second and go from there.
Re: delay box starting out setting [Re: dart games] #2537750
08/17/18 05:48 PM
08/17/18 05:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What kind of car, weight etc and what amount of power. No matter whats said here you will need to make laps to find what works for you. A lot of factors as you say from car reaction to rollout to the human reaction a ton of factors. FWIW my Cuda was 1.140+- usually the dragster is 1.170+-
Re: delay box starting out setting [Re: dart games] #2537870
08/17/18 09:37 PM
08/17/18 09:37 PM
Are you switching from leaving on the bottom bulb and going to letting go of the button the top bulb?
If so what was your average reaction times on the bottom bulb?
It is decent(winning some races) try adding 1.0 and go from there twocents
I'm old and slow so I have .985 in my box with tall front tires shruggy
Re: delay box starting out setting [Re: Blucuda413] #2537881
08/17/18 09:48 PM
08/17/18 09:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats how I started out. up
Re: delay box starting out setting [Re: dartman366] #2537910
08/17/18 10:34 PM
08/17/18 10:34 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
10.50 car, .965. As has been already mentioned, all combos are different.
Re: delay box starting out setting [Re: dart games] #2537938
08/17/18 11:47 PM
08/17/18 11:47 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I set mine at ........
oops shouldn't say anything
Re: delay box starting out setting [Re: nss guy] #2538065
08/18/18 11:56 AM
08/18/18 11:56 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
smile
Re: delay box starting out setting [Re: dart games] #2538132
08/18/18 02:10 PM
08/18/18 02:10 PM
st.louis,mo.
st.louis,mo.
I only run 1/8 mile,1.25 to 1.32 60 ft,28 tall fronts,i suck at foot brake or bottom bulb trans brake,trying to maybee go to a box or get out of racing,car runs 6.30s
Re: delay box starting out setting [Re: dart games] #2538262
08/18/18 10:09 PM
08/18/18 10:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
When we were pro tree racing, we would be at a different place every weekend. I would roll some numbers in so it would be real green for time runs/TnT and leave it alone. We were looking for consistency, difference in the lanes, lighting, sun and shade, etc. For first round we would roll numbers back out to try to get the light we wanted, based on that information.
If you go to the same place every week, it should be easy to get a baseline number.
Re: delay box starting out setting [Re: Blucuda413] #2538273
08/18/18 10:28 PM
08/18/18 10:28 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree you don't have to hit it perfect the first time out, put it at 1 sec make a pass, do the math using your R/T adjust the box accordingly. it is going to take more than one weekend to the thing set
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: delay box starting out setting [Re: W.I.N. Racing] #2538286
08/18/18 10:57 PM
08/18/18 10:57 PM
PA.
"Little"John
"Little"John
PA.
Buy a practice tree. Biondo final round is a nice one. I have a full size practice tree but haven’t used it in years
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: delay box starting out setting [Re: dart games] #2538351
08/19/18 12:40 AM
08/19/18 12:40 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
What is the problem on bottom bulb?
"Just a Bracket car dressed up like a streetcar"
Re: delay box starting out setting [Re: dart games] #2538411
08/19/18 02:03 AM
08/19/18 02:03 AM
st.louis,mo.
st.louis,mo.
I have a practice tree im 58,so im getting killed at the track by reaction times
Re: delay box starting out setting [Re: dart games] #2538412
08/19/18 02:06 AM
08/19/18 02:06 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Doesn't matter what car, et, 60 ft, gear, nothing! Set it at one second and make 4-5 runs, doesn't matter if red or you set there, you're getting a baseline of what you and the car does. Add or subtract the delay to get to an .01 light, then work on consistency.
While setting in line, practice letting the button go on the cars lights up ahead of you.
I had a practice box hooked up in my car that worked off the delay box, blowed everyone's mind. I would do it ten times in a row, wait a little then do over. A lot of double 0s
Re: delay box starting out setting [Re: dart games] #2538473
08/19/18 11:14 AM
08/19/18 11:14 AM
st.louis,mo.
st.louis,mo.
thanks cudaman and all,i have to try something
Re: delay box starting out setting [Re: dart games] #2538738
08/19/18 10:53 PM
08/19/18 10:53 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
I'm 65 and bottom bulb race. Adjust the car to you, not you to the car. Just react and then there are lot's of ways to get the car to react faster or slower to get your rt to where you want it.
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
