Re: 1969 Bahama Yellow
[Re: ubercuda]
#2537757
08/17/18 06:04 PM
08/17/18 06:04 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I picked 3 that are "close", but keep in mind, that shade value/primer base can alter a color slightly, buy the minimum you can and do a spray out to see if it's what you want... I'm leaning towards Boss Yellow with a dark primer/shade value 4-5 Mike
[Re: DAYCLONA]
#2537992
08/18/18 02:39 AM
08/18/18 02:39 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Is there a reason you are forced to use only this supplier?
I absolutely love Bahama Yellow and would hate to see it not as intended. I'm sure he'd be your bestest friend if you bought him all the "correct" Bahama Yellow paint and supplies you feel he needs for HIS "intended" paint project... No problem Dayclona, last I checked we were posting on the “Restoration” site, where correct should be considered. But you’re correct, it is HIS project and hes welcome to paint it with anything he likes
