delay box starting out setting
#2537680
08/17/18 03:10 PM
08/17/18 03:10 PM
Posts: 676 st.louis,mo.
dart games
st.louis,mo.
what would be a good delay box starting out number,i know a lot plays into it,where you put the car in the beams,tire size,tire pressure,rear end ratio,rear tire size,how you see the tree,left lane or right lane,
Re: delay box starting out setting
[Re: dart games]
#2537697
08/17/18 03:49 PM
08/17/18 03:49 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A lot goes into this but with my car doing 1.25-1.27 sixty foot times I'm set at 1.055-1.065 but everyone car, tire size, and suspension is different. Test n tune is your friend for getting it zero'd in.
[Re: dart games]
#2537705
08/17/18 03:57 PM
08/17/18 03:57 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I need 1.10 in mine, torqueflite, 1.26 60 ft, 24.5 tall front runners, leave at 5200 off a 6200 stall, 8.90 ETaverage, 3065 lbs, 33 x15 slicks. car weighs 3065.
[Re: dart games]
#2537750
08/17/18 05:48 PM
08/17/18 05:48 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
What kind of car, weight etc and what amount of power. No matter whats said here you will need to make laps to find what works for you. A lot of factors as you say from car reaction to rollout to the human reaction a ton of factors. FWIW my Cuda was 1.140+- usually the dragster is 1.170+-
[Re: dart games]
#2537870
08/17/18 09:37 PM
08/17/18 09:37 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Are you switching from leaving on the bottom bulb and going to letting go of the button the top bulb? If so what was your average reaction times on the bottom bulb? It is decent(winning some races) try adding 1.0 and go from there I'm old and slow so I have .985 in my box with tall front tires
[Re: Blucuda413]
#2537881
08/17/18 09:48 PM
08/17/18 09:48 PM
dartman366
Mt. Vernon, Ohio
Set it at one second and go from there. thats how I started out.
[Re: dart games]
#2538132
08/18/18 02:10 PM
08/18/18 02:10 PM
dart games
st.louis,mo.
I only run 1/8 mile,1.25 to 1.32 60 ft,28 tall fronts,i suck at foot brake or bottom bulb trans brake,trying to maybee go to a box or get out of racing,car runs 6.30s
[Re: dart games]
#2538262
08/18/18 10:09 PM
08/18/18 10:09 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
When we were pro tree racing, we would be at a different place every weekend. I would roll some numbers in so it would be real green for time runs/TnT and leave it alone. We were looking for consistency, difference in the lanes, lighting, sun and shade, etc. For first round we would roll numbers back out to try to get the light we wanted, based on that information.
If you go to the same place every week, it should be easy to get a baseline number.
[Re: Blucuda413]
#2538273
08/18/18 10:28 PM
08/18/18 10:28 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Set it at one second and go from there. you don't have to hit it perfect the first time out, put it at 1 sec make a pass, do the math using your R/T adjust the box accordingly. it is going to take more than one weekend to the thing set
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2538286
08/18/18 10:57 PM
08/18/18 10:57 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Buy a practice tree. Biondo final round is a nice one. I have a full size practice tree but haven’t used it in years
[Re: dart games]
#2538351
08/19/18 12:40 AM
08/19/18 12:40 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I only run 1/8 mile,1.25 to 1.32 60 ft,28 tall fronts,i suck at foot brake or bottom bulb trans brake,trying to maybee go to a box or get out of racing,car runs 6.30s What is the problem on bottom bulb?
"Just a Bracket car dressed up like a streetcar"
[Re: dart games]
#2538412
08/19/18 02:06 AM
08/19/18 02:06 AM
Posts: 8,282 fredericksburg,va
cudaman1969
fredericksburg,va
Doesn't matter what car, et, 60 ft, gear, nothing! Set it at one second and make 4-5 runs, doesn't matter if red or you set there, you're getting a baseline of what you and the car does. Add or subtract the delay to get to an .01 light, then work on consistency. While setting in line, practice letting the button go on the cars lights up ahead of you. I had a practice box hooked up in my car that worked off the delay box, blowed everyone's mind. I would do it ten times in a row, wait a little then do over. A lot of double 0s
[Re: dart games]
#2538738
08/19/18 10:53 PM
08/19/18 10:53 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
I'm 65 and bottom bulb race. Adjust the car to you, not you to the car. Just react and then there are lot's of ways to get the car to react faster or slower to get your rt to where you want it. Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
