accelerator pump size? #2535373
08/12/18 11:33 PM
08/12/18 11:33 PM
Just South of The Motor City
limechallenger Offline OP
I've got a 70 T/A Challenger with a original 340/6pack, I rarely drive it anymore , but I fired it up the other day and noticed the accelerator pump is leaking pretty bad! So it looks like I will pull the carbs ,anyway I need to know what size diaphragm it has ! E-bay has both 50 cc and 30 cc, anybody know which one I need?
Thanks!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: accelerator pump size? [Re: limechallenger] #2535376
08/12/18 11:39 PM
08/12/18 11:39 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
From pictures I see on line it is the small Accelerator pump
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: accelerator pump size? [Re: limechallenger] #2535385
08/12/18 11:50 PM
08/12/18 11:50 PM
Andrewh Offline
Andrewh  Offline
common would be the 30cc.
I added the 50cc to my carb once. it noticably is larger and hangs down farther.
Re: accelerator pump size? [Re: limechallenger] #2535551
08/13/18 11:37 AM
08/13/18 11:37 AM
Thanks guys!
Re: accelerator pump size? [Re: limechallenger] #2535557
08/13/18 11:47 AM
08/13/18 11:47 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
center carb came with 30cc pump. may not be the pump but a poor seal between the metering block and carb body due to warpage. been thru it!
Re: accelerator pump size? [Re: limechallenger] #2535578
08/13/18 12:35 PM
08/13/18 12:35 PM
The original 30 CC pump diaphragms are black in color and don't last long with todays fuel, I would replace it with one the newer green ones that will last with alcohol up scope
Re: accelerator pump size? [Re: Cab_Burge] #2535598
08/13/18 01:24 PM
08/13/18 01:24 PM
Cab is the man! (& for your app I wouldn't think you'd need the extra squirt from 50CC's)
Re: accelerator pump size? [Re: limechallenger] #2535630
08/13/18 02:26 PM
08/13/18 02:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pull the carb off, remove the pump cover, and using some fine sandpaper on a flat surface (like a pane of glass), sand the mounting flange. I'll bet it's warped. Then use the green diaphragm like Cab advised. Set the lever so that at full throttle there's .050 clearance between the lever and the adjustment screw that pushes on it. Lever should move immediately when throttle is cracked open. Fine-tune adjustment if/as necessary for that.
Re: accelerator pump size? [Re: topside] #2535637
08/13/18 02:38 PM
08/13/18 02:38 PM
^^^ good info (& sand in a figure 8). EDIT with solvent & not sure what grit paper, 600?
Re: accelerator pump size? [Re: limechallenger] #2535702
08/13/18 04:24 PM
08/13/18 04:24 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
There is not enough clearance for 50cc pump on a six pack.
Re: accelerator pump size? [Re: limechallenger] #2535706
08/13/18 04:32 PM
08/13/18 04:32 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Can't speak for a 340, but plenty of room on a 440 6 pack.
Ours is not a race only and the 50 cc was a bit to rich on tip-in.
Went back to a 30 cc with no reduction in crispness.
And yes, get the green ones from Holley.
Joe
Re: accelerator pump size? [Re: jlatessa] #2535719
08/13/18 04:58 PM
08/13/18 04:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
50 cc itself goes not pump any more fuel than a 30 cc. The pump cam dictates total squirt volume. If you use either of the two largest pump cams, you have to use the 50 cc pump or you will bottom out the 30 cc pump diaphram.
Re: accelerator pump size? [Re: lewtot184] #2536099
08/14/18 12:01 PM
08/14/18 12:01 PM
is it gonna warp after 20 years? I built the car in 1992 and have never had a problem, just recently ,it's been a year since I last ran it and the leak developed!
Re: accelerator pump size? [Re: limechallenger] #2536111
08/14/18 12:26 PM
08/14/18 12:26 PM
Green one ordered 30 cc! Thanks!
Re: accelerator pump size? [Re: limechallenger] #2536167
08/14/18 02:12 PM
08/14/18 02:12 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what happens is the body gets distorted from repeated tightening of the float bowl screws. if your carb has had few rebuilds/jet changes/etc then maybe your ok. I know I've chased accelerator pump leaks only to find the weeping was between the metering block and carb body.
Re: accelerator pump size? [Re: lewtot184] #2536241
08/14/18 04:18 PM
08/14/18 04:18 PM
Murphy loves messing with us hot rodders whistling My message is many things, problems, can have the same results cause by several different things shruggy
Re: accelerator pump size? [Re: RATTRAP] #2537446
08/17/18 12:30 AM
08/17/18 12:30 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
i have a 50cc pump on my six pack, plenty of room
Re: accelerator pump size? [Re: jcastle1] #2537488
08/17/18 03:22 AM
08/17/18 03:22 AM
Many people think that when they hear 50 CC pump they think it will squirt 50CC tsk Not in one squirt and the pump will not hold 50 CC either, Holley rates their pump volume in 10 shots so a 30 CC pump is SUPPOSE to squirt 30 CC in ten pumps, not one pump scope
so that means it SHOULD pump 3.0 CC per pump shot work scope
5.0 CC shot volume for the 50 CC pumps for one pump squirt also, if it is adjusted properly up
Re: accelerator pump size? [Re: Cab_Burge] #2537590
08/17/18 12:20 PM
08/17/18 12:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Only if you have the cams to support the 3 and 5 cc lever depression. All of the cams are rated for total squirt volume (per 10 squirts as Cab says)
Re: accelerator pump size? [Re: lewtot184] #2537591
08/17/18 12:24 PM
08/17/18 12:24 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've also had 2 or 3 diagrams start leaking where the little metal disk for the lever to ride on penetrates the rubber diaphragm. FWIW.
