Page 3 of 3 1 2 3
Re: What now for this b1 exhaust port [Re: kevinlc] #2513211
06/25/18 08:55 PM
06/25/18 08:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Be interesting to see more info on the current combo, came compression etc.
Al, he listed the combo:
Originally Posted By kevinlc
The combination is a 15:1 451 cid with b1 original heads, sheet metal intake with two 1050’s, roller cam with .845 intake 285 duration and .766 exhaust and 299 duration ground on 110 lobe separation. Exhaust is 2 to 2/18 equal length. Trans is a 727 with a brake, 5500 stall, 14x32 and 5:13 gears.
Re: What now for this b1 exhaust port [Re: kevinlc] #2513217
06/25/18 09:12 PM
06/25/18 09:12 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Sure seems like one heck of an underperformer. Guess I missed that one.
I should have added check spring pressures as well to the list of places to start looking for missing HP...
Re: What now for this b1 exhaust port [Re: Al_Alguire] #2513298
06/26/18 12:16 AM
06/26/18 12:16 AM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
The combo is a few pages back
Re: What now for this b1 exhaust port [Re: kevinlc] #2513328
06/26/18 01:38 AM
06/26/18 01:38 AM
Las Vegas
Las Vegas
AS I said I would start with basics of troubleshooting to see if there is an underlying issue causing the poor performance.
Re: What now for this b1 exhaust port [Re: Al_Alguire] #2513407
06/26/18 11:06 AM
06/26/18 11:06 AM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
That’s what I’m going to do since it’s apart for it’s normal freshen up
Re: What now for this b1 exhaust port [Re: kevinlc] #2534281
08/10/18 05:10 PM
08/10/18 05:10 PM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Update. Sent the heads to CFE. Here is the email
Kevin,
there are some improvements to consider on the B1's. First would be from doing our valve job (which would add some much needed area under the exhaust valve), open up the bowls on the intake side to the common bolt hole (you would need to seal those bolt columns off with silicone during assembly), and straightening on some things in the chamber, particularly on the exhaust side. The chambers are all over the place in respect to transitioning to the bore diameter and some are opened up to 4.500" and over-hang the deck on your smaller bore diameter. Not the end of the world, but I thought I should mention it. As noted, we can straighten some of that out where there is material to work with.
If interested, we could do our touches to them and the cost would be $1,800.00. The time frame would be two or three weeks at the most. If interested, and you'd like us to proceed, let me know and give me the specs on your current cam. I can give you some direction on what to do in that department.
Let me know if you have some questions. We appreciate your interest.
Scott @ CFE
Re: What now for this b1 exhaust port [Re: kevinlc] #2534297
08/10/18 05:41 PM
08/10/18 05:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
WOW!!!!!!!! 1800.00 MORE.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What now for this b1 exhaust port [Re: pittsburghracer] #2534319
08/10/18 06:25 PM
08/10/18 06:25 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
That is the going rate to have any good shop hand work any head.
Re: What now for this b1 exhaust port [Re: kevinlc] #2534325
08/10/18 06:38 PM
08/10/18 06:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
The question I’d be asking myself is, how much improvement(ET) would I have to see out of the $1800 head work for me to feel like I got what I paid for?
And then, is that expectation realistic for what they’re proposing?
I’d pay those guys to flow them as-is to see how well the numbers correlated to the numbers you already have before making any decisions about proceeding further.
My preference would be to flow them on as correct a bore size as they have, and with/without a correct sized flow tube.
Re: What now for this b1 exhaust port [Re: Biginchmopar] #2534330
08/10/18 06:53 PM
08/10/18 06:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What, exactly, does that $1800 get the OP? I saw reference to:
- valve & seat rework
- bowl enlarging
- some chamber work
Am I missing something else? Big-name shop or not, that seems like a lot of $$$ for just that amount of work.
PLEASE tell me I've misread what that quote includes...
Re: What now for this b1 exhaust port [Re: BradH] #2534349
08/10/18 07:46 PM
08/10/18 07:46 PM
Washington
madscientist Offline
Washington
- bowl enlarging
- some chamber work
I suspect they will be doing some repairs. Sounds like the chambers need some welding. Who knows what they need to do to fix the valve job.
I always charge more when I have to fix someone else's junk work. I especially hate trying to fix absurd valve jobs.
Sometimes, as I got older, I just turned some of the fix my junk [censored] away. Just wasn't worth the crap.
Re: What now for this b1 exhaust port [Re: madscientist] #2534396
08/10/18 10:40 PM
08/10/18 10:40 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
Darren at reher morrison quoted around 3500 to hand port a set, they dont have a cnc program for b1. I believe it was around 90 pesos an hour. The ideal person to get them to would be radar, if you can find him....
SFI 25.5 depends,no leak,even at 213 mph....
Re: What now for this b1 exhaust port [Re: BradH] #2534502
08/11/18 11:10 AM
08/11/18 11:10 AM
The Great White North
RAMM Offline
RAMM  Offline
- bowl enlarging
- some chamber work
It all boils down to how much faith you have in XX shop. EVERYTHING has gone up in price EVERYTHING. Why not highly specialized shops with highly specialized skills with highly specialized equipment? I charge $105 CDN/hr and its barely enough, but you know what? People pay or they have to learn how to do it themselves--then they realize how cheap it was to send it to the machine shop in the first place. On the flip side of this coin are the idiot machine shops that still charge $100 bucks for a valve job or $75.00 for a line hone--they must like working at a loss. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: What now for this b1 exhaust port [Re: RAMM] #2534603
08/11/18 03:12 PM
08/11/18 03:12 PM
BradH Offline
BradH  Offline
Jesse - No question that quality work with precision equipment justifies a fair & profitable price. However, this isn't the first time I've seen prices quoted/listed for specific jobs that were so much higher than what some other good shops charge that I suspect the difference was because of whose business name is on the top of the invoice.
Re: What now for this b1 exhaust port [Re: RAMM] #2534673
08/11/18 05:31 PM
08/11/18 05:31 PM
Washington
Washington
- bowl enlarging
- some chamber work
Truer words have not been spoken.
Page 3 of 3 1 2 3
