Page 1 of 5 1 2 3 4 5
What parts for your mopar would you like to see reproduced? #2534317
08/10/18 06:22 PM
08/10/18 06:22 PM
moparmadman69 Offline OP
Just want to get some ideas on what isn't made currently for A/B/E body that is desperately needed. The hobby has come a long way as regards to parts availability but there are still some big holes out there.
Colby Boyce
Tech, Sales & Customer Service
Accurate Ltd.
541-672-2661
http://www.accurateltd.com/
accurateexhaustltd@outlook.com
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534320
08/10/18 06:32 PM
08/10/18 06:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Rubber seals / weatherstripping for 4 doors & station wagons.
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534327
08/10/18 06:41 PM
08/10/18 06:41 PM
KY
65pacecar Offline
65pacecar  Offline
KY
1965 Sport Fury (C Body) trunk Finish Panel, upper and lower Trunk Moldings.
1967 B Body (Plymouth and Dodge) Quarter panels (Full)
1965 Fury Quarter Panels (Full) or even quality Half/Patch.
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534377
08/10/18 09:05 PM
08/10/18 09:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
76-77 f body gas tank, sorely needed
Re: What parts for your mopar would you like to see reproduced? [Re: mopars4ever] #2534381
08/10/18 09:34 PM
08/10/18 09:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
So far none of the items listed will see the day of light, unless an enthusiast/business owner requires that part for his/her own vehicle(s), or an avid enthu$ia$t inve$t$ in it'$ production... as the investment to produce it far outweighs it's return on just the initial investment, never mind any/if at all potential profit
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534384
08/10/18 09:43 PM
08/10/18 09:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What "holes" are you looking to fill?, driveline, suspension, sheetmetal, potmetal, stainless /aluminum trim, wheels, interior, etc, etc, etc, etc, etc, etc, etc ???????????????????????????????
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534400
08/10/18 11:00 PM
08/10/18 11:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some of us can be more optimistic & focus on what we would like to see since it was asked. boogie
In other, very optimistic news - TA rocker arm sets may become available again if all keeps going well. up
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534401
08/10/18 11:16 PM
08/10/18 11:16 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Hmmm.... Vans auto makes or sells a gas tank sending unit for the lowly 76-77 f body that wasn`t available just a few years ago. He has sold a good amount of them on ebay and elsewhere.
Re: What parts for your mopar would you like to see reproduced? [Re: mopars4ever] #2534423
08/11/18 12:35 AM
08/11/18 12:35 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct 70 and later A-body gas tanks
66/67 Plymouth B-body full 1/4 panels
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534441
08/11/18 01:36 AM
08/11/18 01:36 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
1969 Plymouth Barracuda lower rocker molding and clips.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534443
08/11/18 01:45 AM
08/11/18 01:45 AM
MO
cdp Offline
cdp  Offline
MO
71 B-body seat foam.
Re: What parts for your mopar would you like to see reproduced? [Re: cdp] #2534448
08/11/18 02:14 AM
08/11/18 02:14 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Rubber/Vinyl floor mats. The OG translucent colored ones that you used to find in original cars years ago. Have not seen those in many years.
Pushbutton radio buttons. Chrome is always pitted or flaked.
Brake splash shields.
70-71 Dodge Challenger bumper guards. Someone on here was looking for those and turns out they are hard as hell to locate.
Radiator support to k-member brackets. Often full of gouge marks from hitting concrete curbs or wheel stops.
Brake rotor outer wheel bearing dust caps.
Correct chrome rallye wheel lug nuts.
Rallye wheel trim rings. Don't even think you can find 14" ones anymore, and clean 15x7 ones are worth stupid money now.
OEM style lower control arm sway bar brackets that can be welded to non-sway bar control arms. 67-72 a-body lower control arms with sway bar tabs are not cheap anymore.
Heater box housings would be cool, but doubt that would be cost effective. Many are dried out or cracked so it's getting hard to find nice ones if you building a high end car.
Mod tops and gator tops.
How about 904 and 727 oil pans? Maybe make them out of thicker metal too?
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534460
08/11/18 02:39 AM
08/11/18 02:39 AM
AndyF Offline
AndyF  Offline
Whatever you decide to make please make it as good as the original. I've been buying reproduction parts for a while now and most of it is garbage. People are spending a lot of money tooling up parts that don't fit. Not sure if the Chinese can't read blueprints or what the problem is but it is really rare to take a repo part out of the box and have it fit and work like an original part.
Re: What parts for your mopar would you like to see reproduced? [Re: AndyF] #2534481
08/11/18 08:15 AM
08/11/18 08:15 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
71 Charger fenders
Re: What parts for your mopar would you like to see reproduced? [Re: cdp] #2534486
08/11/18 08:58 AM
08/11/18 08:58 AM
MA
steve70 Offline
steve70  Offline
MA
Now available from Legendary
1970 Challenger T/A 4 speed
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534524
08/11/18 12:06 PM
08/11/18 12:06 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
70 C body sheet metal . . . I know, a small select group of folk would want these . . . but nicer than trying to patch and use the best of the whats left.
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534586
08/11/18 02:22 PM
08/11/18 02:22 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
The following B body items:
66-70 convertible top header panel repair panels.
66-67 seat tracks
66-67 lower trunk repair panels
Heat riser repair kits
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534736
08/11/18 07:56 PM
08/11/18 07:56 PM
Bakersfield, California
Mopar Paul Offline
Mopar Paul  Offline
Rocker molding clips for a 1969 Plymouth Sport Satellite. One of a kind . AKA "Hens teeth"
https://www.forbbodiesonly.com/moparforum/attachments/rocker-clips-004-2-jpg.180204/
Re: What parts for your mopar would you like to see reproduced? [Re: BloFish] #2534769
08/11/18 09:35 PM
08/11/18 09:35 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Correct 14" & 15" trims rings both brushed and polished
Re: What parts for your mopar would you like to see reproduced? [Re: moparmadman69] #2534808
08/11/18 10:40 PM
08/11/18 10:40 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
A CORRECT, trunk mat! up
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
