63-67 b body- reducing drag coefficient #2534224
08/10/18 03:22 PM
08/10/18 03:22 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
hey guys: Anyone done any work on cleaning up airflow/turbulence on mid/late 60"s B bodies?
I cannot help but notice the front of the K member area catches air badly as well as other areas.
Not finding much info.
May start another thread for the late 60"s b bodies and one for the A bodies through mid 70's.
from about 70 mph up these areas certainly, effect et/mph so i thought I would ask if anyone has worked on reducing air turbulence /drag.
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534235
08/10/18 03:44 PM
08/10/18 03:44 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Get the car as low as possible, and put an air dam on the front, under the bumper.
69 GTX 68 Road Runner
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534254
08/10/18 04:14 PM
08/10/18 04:14 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I think Chrysler recognized back when the cars were new. I've seen a lot of photos of the '64-67 cars with an air dam located as stated above, below the front bumper. Some racers rolled their's around underneath, creating a small belly pan effect. There was also the factory "bubble" windshield for the '65 FX cars.
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534268
08/10/18 04:36 PM
08/10/18 04:36 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
anyone have links for pics?
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534275
08/10/18 04:44 PM
08/10/18 04:44 PM
fullmetaljacket Offline
One cheap way is to paint most all jagged edge parts gloss black, especially the big K-member. Gloss paints are more slippery in the air compared to the stock look of matte/satin finishes of the day.
Dams can be constructed as said and serve two purposes for speed and safety. I've been planning on creating one out of aluminum sheet to be detachable or reinstall able at any time at the track for a street/strip setup.
Re: 63-67 b body- reducing drag coefficient [Re: fullmetaljacket] #2534282
08/10/18 05:14 PM
08/10/18 05:14 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The name of my car is the "Blunt object " It cuts right thru the air !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534286
08/10/18 05:24 PM
08/10/18 05:24 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
indeed bigdad.
Wonder what the results would be of closing up the front holes in the Kmember with light alum on one with stock kmember.
We put a Gerst suspension on the duster and one can visually see a huge difference in air catchment between it and a stock k member.
I'm willing to bet even money that cars with stock k member are harder on engine cooling than cars with a Tubular k.
Re: 63-67 b body- reducing drag coefficient [Re: bigdad] #2534288
08/10/18 05:25 PM
08/10/18 05:25 PM
That there is the boxiest that they come, but beautifully designed and most sturdiest for dragging.
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534334
08/10/18 07:00 PM
08/10/18 07:00 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IIRC a panel covering the open space between the bottom of the front pan and the K member helps, but it increases oil temp.
You're probably catching air under the trunk, but what to do?
For best effect the dam should be as low as possible, a rubber skirt bottom (I've seen garage door skirts used) gets it closer without being wrecked when the nose dives, curbs, driveways, trailer ramps.
If legal (or you don't care!), it should project forward ahead of anything else, and angle back ending at the radiator core bottom.
Boffin Emeritus
Re: 63-67 b body- reducing drag coefficient [Re: polyspheric] #2534335
08/10/18 07:04 PM
08/10/18 07:04 PM
I made dams for my rear bumper years back out of aluminum thin sheet. Large area of catch basin back there that also slows those cars down. Lots of air management is more effective underneath more than up top sometimes.
Re: 63-67 b body- reducing drag coefficient [Re: polyspheric] #2534343
08/10/18 07:19 PM
08/10/18 07:19 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Good thoughts Poly.
On the 65 k member area, there are two areas that together make up about a 2.5 sq ft parachute!
If i fill those in with thin alum., the deep pan remains fully exposed to air flow but the bottom of radiator core support to k member now directs air down and back towards oil pan.
I think it will work, look nice and clean up that air path from a catchment, turbulence area to useful airflow.
Re: 63-67 b body- reducing drag coefficient [Re: fullmetaljacket] #2534344
08/10/18 07:21 PM
08/10/18 07:21 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
I hadn't thought about looking at the rear bumper, will do so this weekend.
Do you have any pics on how you did yours?
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534444
08/11/18 02:08 AM
08/11/18 02:08 AM
Yes I do, but I would have to look through quite a few photos. Be patient being that I'm busy traveling.
Re: 63-67 b body- reducing drag coefficient [Re: fullmetaljacket] #2534469
08/11/18 03:25 AM
08/11/18 03:25 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thank you !
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534609
08/11/18 03:33 PM
08/11/18 03:33 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Originally Posted By RustyM
indeed bigdad.
I have a Gerst front on mine too
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534619
08/11/18 03:52 PM
08/11/18 03:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Aero works like this: oncoming air that gets into the engine compartment, hits undercarriage projections, and which eddys behind the car all create drag, lift, and slows the car; also requires a lot more power to overcome at steady high speeds.
'66-'67? Look at Petty's Cup car towards the end of the '67 season: gaps closed up, sits low at about 5-degree rake, tight/faired bumpers. See also Smokey Yunick's infamous Chevelle and TransAm Camaro.
Keeping the air from getting under the car (air dam) solves a lot of it, because that air hits & bounces around everything.
For a drag car, not enough time is spent at high speed to make all the tricks ET-effective, plus there's weight to consider.
But addressing the nose, reducing grille intake, removing or smoothing things that catch air, all help aero.
A short rear spoiler also helps passing air attach to the trunk lid and cause a tapering effect behind the car, which reduces drag and reduces lift.
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534635
08/11/18 04:32 PM
08/11/18 04:32 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks Topside
Re: 63-67 b body- reducing drag coefficient [Re: RustyM] #2534708
08/11/18 06:49 PM
08/11/18 06:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You're quite welcome. "But Wait, There's More", haha...
Aero research on vehicles pretty much started with the Germans in the 1930s, and other sources for info would include an article by Car and Driver using a Dodge B-van, teh 2nd versionof the original '65 HemiCuda drag car, the Chrysler engineers' work with the Charger 500 & wing cars, early on in the TransAm series when they started drooping the noses, and later when the windshields were laid back a little and the upper cab subtly reshaped (Yunick's '68 Camaro) into a more fastback shape, drip channels set flush. That car & the Chevelle Cup car had a lot of underside fairing done, even with their creative ft air dam work.
A 3.5" rear spoiler at a 45 on the back of Melrose Missile VII picked up about 6-7 MPH and about .4 ET IIRC, though that was a 160MPH+ car on fuel at the time. Basically the car was spinning the rear tires from lift.
Bang for buck on a drag car like a '66-'67 B would likely be blanking off openings within reason, dropping the nose, and an air dam; reducing the frontal area would be nice, but a lot of work.
Re: 63-67 b body- reducing drag coefficient [Re: topside] #2534842
08/11/18 11:31 PM
08/11/18 11:31 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
LOL, I have the WORSTE a 66 coronet! The grill is FLAT, ugly and a total air trap! I don't think they even tried the 66' Coronet on super speedways, it was OBVIOUS that they were an air plow!
Re: 63-67 b body- reducing drag coefficient [Re: fullmetaljacket] #2534887
08/12/18 01:14 AM
08/12/18 01:14 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
eek laugh2
https://en.wikipedia.org/wiki/Boundary_layer_thickness
