Re: 340 Rear Main Seal
[Re: DUSTER_340]
#2533545
08/09/18 12:01 AM
08/09/18 12:01 AM
RapidRobert
are those "side" seal pieces seating flush?
[Re: DUSTER_340]
#2533556
08/09/18 12:28 AM
08/09/18 12:28 AM
RapidRobert
I ain't sure, more just thinking out loud than fact. You said it looked like it was coming thru (past) the seal or around it?
[Re: RapidRobert]
#2533702
08/09/18 12:44 PM
08/09/18 12:44 PM
RapidRobert
I think what I would do is do it over again (no choice really) & clean everything squeaky clean (which I know did) & likely a new pair of superformance seals. slightly polishing the knurl down a bit may help/be a good move. Did you say there was a slightly oversize seal available? I wondering is some nonhardening cement (a touch of permatex #2) on the ends where they meet as opposed to some hardening stuff would allow the seal to move slightly/conform a bit better to the round crank.
[Re: RapidRobert]
#2533718
08/09/18 01:00 PM
08/09/18 01:00 PM
360six
[Re: DUSTER_340]
#2533791
08/09/18 02:57 PM
08/09/18 02:57 PM
360six
pretty sure Top Half is backwards. ? maybe not. carry on
[Re: cudaman1969]
#2533832
08/09/18 04:43 PM
08/09/18 04:43 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
Look closer they are not backwards. they have a little lip at the back but the main angle is definitely toward the inside of the engine.there is a double lip on some small block seals.
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: gzig5]
#2533939
08/09/18 09:05 PM
08/09/18 09:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Why is the crank knurled on the sealing surface? That seems counterproductive. Because when you use a rope seal, like original, it seals.
[Re: DUSTER_340]
#2533992
08/09/18 11:38 PM
08/09/18 11:38 PM
Supercuda
About to go away
About to go away
up yours
I can't remember the last time I replaced a rope seal. Probably in 88. Not even sure if you can get them any more, but the knurled surface was used in conjunction with rope seals back when the factory used rope seals.
[Re: jwilson 61]
#2534036
08/10/18 01:56 AM
08/10/18 01:56 AM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Look closer they are not backwards. they have a little lip at the back but the main angle is definitely toward the inside of the engine.there is a double lip on some small block seals. That little lip goes to the inside, but you do it the way you want. Let the drips begin. The serrations are made to force the oil back into the engine no matter what type seal you use.
