Re: Availability of Mopar Perf. engine paint??
[Re: SlickRS23]
#2533542
08/08/18 11:57 PM
08/08/18 11:57 PM
RapidRobert
Jeff, on a side note (fwiw) the "race hemi orange" looked much closer to some OE orange valve covers I had & the "street hemi orange" had a weird reddish tint, not even close, but this was 20 yrs ago.
[Re: SlickRS23]
#2533547
08/09/18 12:04 AM
08/09/18 12:04 AM
RapidRobert
Alright. I coulda swore I just saw some on eBay. EDIT I'm assuming summitt/jegs/mancini are empty.
[Re: SlickRS23]
#2533658
08/09/18 11:20 AM
08/09/18 11:20 AM
Posts: 2,726 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Unless something has changed the Mopar paint is so off color it's unusable. Try Totally Auto. Expensive, but you're driving a Mopar so you're used to it.
2011 Drag Pak Challenger
[Re: Neil]
#2534258
08/10/18 04:19 PM
08/10/18 04:19 PM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
I stopped buying it as the colors were not the same can to can. You had to use one can to do the final top coat on all the parts, or you weren't going to like the final results. Yes Neil, I had that problem on the last engine I painted "Race Hemi Orange". I used some paint from Jegs and some from Mancini. I like to paint everything separate, though not correct as bomb painting a completed engine, I feel it turns out nicer. I was thinking like you suggested as I still have about a can and a half left, all with the same lot number. Would like to pick up 2 more cans and top coat it with what I have left. Thanks, Jeff
