porting burrs: which ones/where to get em #2533123
08/08/18 01:24 AM
08/08/18 01:24 AM
RapidRobert Offline OP
I have some alum and iron/steel to do. Any tips on making em last/which types for alum/which for iron/steel. Thank you for your time.
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533137
08/08/18 01:58 AM
08/08/18 01:58 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother gets his from a couple tool places in town, but he has been chasing them for years as the places either stop stocking them, or go out of business. He spins the cutting ends in some sort of wax stick to keep the aluminum from clogging up the bits. I don't think cast iron sticks to them.
Summit Racing sells them.
https://www.summitracing.com/search?Sort...=porting%20bits
Re: porting burrs: which ones/where to get em [Re: Neil] #2533142
08/08/18 02:25 AM
08/08/18 02:25 AM
they do have a bunch of em & I do have a candle I got to wick into stuck NPT fittings so I can also use it for the burrs.
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533146
08/08/18 03:05 AM
08/08/18 03:05 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Used to get Buckeye carbide, but it seems they got bought out.
Burrs4less and Lehigh Abrasives are both good suppliers IME.
Cast iron seems to work better with fine cut and aluminum with a much larger coarse cut flute. Bees wax works well, soap does OK, for helping prevent load-up. S/F....Ken M
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533182
08/08/18 10:15 AM
08/08/18 10:15 AM
crabman173
crabman173
for aluminum just dip burr in ATF fluid every minute or so works great
get burrs with long shafts then cut shafts to length you really need for your heads and what you are doing
Re: porting burrs: which ones/where to get em [Re: ] #2533263
08/08/18 01:17 PM
08/08/18 01:17 PM
Good info/noted/just what I was after/thanks guys!
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533301
08/08/18 02:46 PM
08/08/18 02:46 PM
dogdays Offline
dogdays  Offline
Do a search for "carbide burrs" and you'll be swamped.
The big industrial supply houses all sell them - McMaster-Carr, Grainger, MSC.
I used grinding bits when I did my 302s. Those were the abrasive on a stem things that came with the die grinder. My favorite by the time I got done was sort of bullet shaped with a rounded end, about 3/4 of an inch length of stone, maybe 3/8" in diameter.
They are also called "burs". The longer shaft ones can bend if you're not careful.
R.
Re: porting burrs: which ones/where to get em [Re: dogdays] #2533327
08/08/18 03:45 PM
08/08/18 03:45 PM
crabman173
crabman173
Here is good tip for cheapo grinder
$20 straight grinder from Harbor Freight--add length of pipe for $1.50 from hardware store now you have a decent long grinder you can control with both hands like the pros Cheap and it works like a dream
Re: porting burrs: which ones/where to get em [Re: ] #2533693
08/09/18 12:29 PM
08/09/18 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 2 set ups for doing heads.. one is a
electric die grinder with a variable speed
controller and a air powered one.. I like to
keep both set ups light(hours at a time does
get tiring on the hands).. I have about 25
burs for different jobs.. alum heads I use
the course burs and tootsie rolls.. iron I
use the finer burs.. I spray WD40 on the iron
burs and bees wax on the alum burs.. I like
the 1 1/2" long burs for most of my work.. I
have 1.5", 3", 6" and 1 12" long burs the short
ones are easier to control.. dont let the burs
get hot(thats usually a dull bur or its loaded
up)
wave
Re: porting burrs: which ones/where to get em [Re: MR_P_BODY] #2533697
08/09/18 12:35 PM
08/09/18 12:35 PM
Good info & I have a straight grinder that I can certainly add a length of NPT pipe to, for better control/leverage. I'm assuming (like anything else) that quality (more $$$) burrs will last much longer than the pkgs of 4-6 I see on eBay (made in china I would assume).
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533712
08/09/18 12:54 PM
08/09/18 12:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes.. buy the good ones.. cheap ones do get
dull.. I quit buying cheap ones years ago
wave
Re: porting burrs: which ones/where to get em [Re: MR_P_BODY] #2533715
08/09/18 12:56 PM
08/09/18 12:56 PM
Mr P I will take your advice
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2533748
08/09/18 01:39 PM
08/09/18 01:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Don't get wrapped up in the single cut burrs for aluminum, double cut burrs for cast iron BS. Single cuts burrs dig and bounce and if used especially by someone inexperienced become dull quickly and if its a long shaft, BEND. I use a foot controller to control my grinder speed and when done with a double cut burr doesn't even need sanding rolls to clean up. Bottom line is we aren't doing it for a customer to push out the door so "slow down"
Porting tools 005_zpsjgwy0cgl by John Cadamore, on Flickr
Porting tools 002_zps56hn5i69 by John Cadamore, on Flickr
Porting tools 004_zpslw8s6tvt by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: porting burrs: which ones/where to get em [Re: pittsburghracer] #2533787
08/09/18 02:53 PM
08/09/18 02:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Got my last ones from www.burrs4less.com
Re: porting burrs: which ones/where to get em [Re: BradH] #2533942
08/09/18 09:16 PM
08/09/18 09:16 PM
OK, double cut burrs it will be & go slow. Brad those are some good prices.
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2534211
08/10/18 03:00 PM
08/10/18 03:00 PM
BradH Offline
BradH  Offline
Decent prices and a pretty good selection of sizes, shapes and cutter styles. I picked up some high-helix cutters to try out the last time I bought stuff. They kind of split the difference between the full aluma-cut and single/double-cut style that's more suited to iron & steel.
You can use single/double-cut on aluminum, but absolutely must use grinder's grease (like a wax stick) or some type of fluid that helps resist the clogging issue. Also, keep a stiff wire brush handy to reduce the buildup before re-treating the cutter regularly during use.
I used to get my carbides from the Mondello Technical School before ol' Joe passed away. I don't know what they even sell any more, if anything, since then.
Re: porting burrs: which ones/where to get em [Re: RapidRobert] #2534219
08/10/18 03:14 PM
08/10/18 03:14 PM
PA.
"Little"John
"Little"John
PA.
https://mondelloperformance.com/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: porting burrs: which ones/where to get em [Re: pittsburghracer] #2534246
08/10/18 03:55 PM
08/10/18 03:55 PM
BradH Offline
BradH  Offline
Originally Posted By pittsburghracer
I don't know the history, but THAT Mondello business was not owned or run by Joe himself when he started the Mondello Technical School and relocated it to Tennessee. After Joe's death, I think the tech school morphed into an engine-building shop.
