505 build opinions Take 2
#2532397
08/06/18 06:07 PM
08/06/18 06:07 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
A few weeks back I started a thread regarding my RB based stroker build asking for "your 2 cents". I am finalizing my purchase list and would like some input on cam choice. I spent some time on the phone with the guys at Hughes Engines and they seemed pretty excited about this specific grind noted below. I attached a link to the original thread for anyone who wants to get caught up. https://board.moparts.org/ubbthreads/ubbt...tml#Post2522684The build as it sits on paper: RB based 440 Source 505/512 4.25 stroke 4.350 bore -17cc dished pistons 440 source main caps ARP studs Trick Flow 240 Heads Trick Flow Single plane intake Harland Sharp 1.5 Rockers Hughes Solid Roller Cam: 260/264 .675/.675 lift @110* Installed ADV 4* The Magic Bench Dyno says 666HP at 5700rpm and 650ftlbs at 4200rpm Does this seem legit? Thoughts opinions? Thanks
Re: 505 build opinions Take 2
[Re: MrMayhem]
#2532437
08/06/18 07:13 PM
08/06/18 07:13 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Should peak a little higher than 5700 with that cam and intake, if using 2” headers.
[Re: MrMayhem]
#2532457
08/06/18 07:50 PM
08/06/18 07:50 PM
fast68plymouth
So. Burlington, Vt.
Well..... yeh....... but, but, but.........
“Well into the 650-700hp range”........along with A/C with overdrive....... and old school NA stock block RB based stroker....... doesn’t add up too well IMO.
But...... it’s not my car.
Targeting a hp goal for a street cruiser is a bit ambiguous, unless there’s an ET you’re chasing. But then how well the car is set up becomes part of the discussion, especially if the ET goals are kinda lofty. If it’s a situation where the car might make a few trips down the 1/4 mile each year....... then I’d concentrate on how it will drive the other 99% of the time.
Depending on where it was being tested, that combo would get you well into the 650-700hp range(or more)........ or get you close.
[Re: Thumperdart]
#2532476
08/06/18 08:24 PM
08/06/18 08:24 PM
Posts: 4,715 Wichita
GY3
Wichita
Come by the house and ride in my car.
For me, in my car, that cam is a little large..
[Re: GY3]
#2532500
08/06/18 09:00 PM
08/06/18 09:00 PM
Thumperdart
State of confusion
For me, in my car, that cam is a little large.. Quite a drive from Cally...........
[Re: MrMayhem]
#2532519
08/06/18 09:47 PM
08/06/18 09:47 PM
Posts: 12,351 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I agree with others here that, depending on your experience with hotter cams on the street, 260*+ might be a bit of a burden in traffic. Now some guys run that duration and bigger, but not everyone would like what that cam will do to the idle, off idle transitions and maybe even cruise. Certainly a matter of personal taste and comfort. Personally, in my 440 based 500", 250* was about my limit of comfort. I have ran 10 or 12 different cams from 245* to 260*. And don't forget that the EFI will not like the lope at lower engine speeds. You will need to lock it out and manually set it until the engine smooths out and the O2 can give reliable readings. And one last thing, with that much power available, it will take some time figuring out the suspension so that you can transfer much of it to the ground. And on the street, it will take a lot of work and experimentation to get 600HP or so to the ground. It can, of course, be done. But it won't be easy. Heck, 600+HP can be a challenge to hook consistently at the track for a street car. It would be my suggestion that you pull back some on the cam. If you end up putting too small a cam in, you can always stab in a bigger one at some point. But the car will be more flexible and enjoyable with a cam too small than it would be with a cam too large. In this kind of combo, a guy's first time rarely gets everything right right off. You just hope to get as close as possible without making any big mistakes and dial it in from there.
Master, again and still
[Re: Thumperdart]
#2532604
08/07/18 12:53 AM
08/07/18 12:53 AM
GY3
Wichita
For me, in my car, that cam is a little large.. Quite a drive from Cally........... OP is only a couple of hours from me in OKC.
[Re: MrMayhem]
#2532615
08/07/18 01:28 AM
08/07/18 01:28 AM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
My hydr roller is smooth @ 1800 rpm in OD & converter locked up,512ci,255,258 @ .050 cam, I am on the VERY edge for my set up, has taken a lot of tuning to get it happy in all driving conditions.
[Re: AndyF]
#2532632
08/07/18 02:22 AM
08/07/18 02:22 AM
CSK
Pattison Texas
That is about 10 degrees larger than what I'd recommend for someone who wants to cruise on the freeway in OD but it sounds like you got it working.
I have a 246 cam in my 512 and it is okay on the freeway in 5th if I'm running 70 mph or higher. If I hit slow traffic and have to drop down to 50 or 55mph then I need to downshift to 4th gear.
So freeway cruising in light traffic is one thing, navigating a crowded freeway might be another variable. In Portland the freeways can clog up most any time of day so you always have to be ready to slog your way home. A cam that is too big just makes a bad drive worse... When I get in a slow down traffic situation, I just flip my lock up switch off & stay in OD, no big deal on my set up.
