Re: U.S. Radiator quality...
[Re: lewtot184]
#2532545
08/06/18 10:42 PM
08/06/18 10:42 PM
Posts: 3,397 Pa
Hot 340
Pa
i bought one direct from them. piece of crap. expensive lesson. ok..bummer. Thank you for the heads up. Not crazy about the aluminum radiator route though..
[Re: Hot 340]
#2532626
08/07/18 02:01 AM
08/07/18 02:01 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I have a US Radiator in both my Mopars. Awesome quality, work great and never had a problem in over 7 years on one and 4 years on the other. I don't like the look of aluminum radiators in old Mopars.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: lewtot184]
#2532949
08/07/18 07:22 PM
08/07/18 07:22 PM
Posts: 3,397 Pa
Hot 340
Pa
i bought one direct from them. piece of crap. expensive lesson. Can you elaborate a little bit? Id appreciate all the input good and bad...
[Re: mopars4ever]
#2532963
08/07/18 07:46 PM
08/07/18 07:46 PM
Posts: 10,049 MN
JERICOGTX
MN
I bought this one for my Road Runner, since it looked similar to the stock 26". I have since bought a 22" for my Dads Super Bee, and it has worked great. Fit perfectly, and works way better than the original one. I had them both powder coated on the tanks and mounting brackets, then used aerosol to paint the fins.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2532965
08/07/18 07:49 PM
08/07/18 07:49 PM
Posts: 3,397 Pa
Hot 340
Pa
I bought this one for my Road Runner, since it looked similar to the stock 26". I have since bought a 22" for my Dads Super Bee, and it has worked great. Fit perfectly, and works way better than the original one. I had them both powder coated on the tanks and mounting brackets, then used aerosol to paint the fins. Nice...is that the standard core? High effeciency core? optima core?
[Re: Hot 340]
#2532981
08/07/18 08:22 PM
08/07/18 08:22 PM
Posts: 3,916 usa
lewtot184
usa
i bought one direct from them. piece of crap. expensive lesson. Can you elaborate a little bit? Id appreciate all the input good and bad... after a couple hundred miles the top tank split open. took the radiator to the repair shop and tubs were soldered shut and partially shut. I knew then why it wouldn't cool. basically core was screwed up plus repairs. there was a thread over on FBBO about u.s. radiator a year or so ago; maybe it's archived. the real issue with this kind of stuff is you have no idea what your buying until you get into them. I seriously doubt u.s. radiator does much in the way of quality control. probably a high volume production business. if it were me i'd find a reputable local shop and see if they can build what you need. other than that it's just a crap shoot.
[Re: Hot 340]
#2533042
08/07/18 10:24 PM
08/07/18 10:24 PM
Posts: 10,049 MN
JERICOGTX
MN
I bought this one for my Road Runner, since it looked similar to the stock 26". I have since bought a 22" for my Dads Super Bee, and it has worked great. Fit perfectly, and works way better than the original one. I had them both powder coated on the tanks and mounting brackets, then used aerosol to paint the fins. Nice...is that the standard core? High effeciency core? optima core? I got them from www.autocityclassic.com. The website might not show everything, but they do have them for Mopars. Just call them up and ask. Not sure who makes them though.
69 GTX
68 Road Runner
