Re: Difference between small block and big block
[Re: 1fastrunner]
#2530299
08/02/18 01:09 AM
08/02/18 01:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Is this redundant redundancy day?
Without all the redundancies, what?
[Re: 1fastrunner]
#2530369
08/02/18 09:36 AM
08/02/18 09:36 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Hi, I'm referring to differences between items that would differentiate items different on 70's Challengers and Dusters with small block v-8's and big block v-8's. Duster never came with a big block.
[Re: 1fastrunner]
#2532156
08/06/18 06:33 AM
08/06/18 06:33 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
T bar thickness Sway bar thickness ( not allways ) Radiator core support opening
Then some other stuff like differential, but some HP SBs could get same diff than some BBs
Rest is the same.
