Difference between small block and big block #2530281
08/02/18 12:08 AM
08/02/18 12:08 AM
Hunt Valley, Maryland
1fastrunner Offline OP
Hi,
I'm referring to differences between items that would differentiate items different on 70's Challengers and Dusters with small block v-8's and big block v-8's.
Re: Difference between small block and big block [Re: 1fastrunner] #2530299
08/02/18 01:09 AM
08/02/18 01:09 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Is this redundant redundancy day?
Without all the redundancies, what?
Don't be the exception.
Re: Difference between small block and big block [Re: 1fastrunner] #2530308
08/02/18 01:33 AM
08/02/18 01:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The question is poorly constructed. Try different words.
Re: Difference between small block and big block [Re: 1fastrunner] #2530312
08/02/18 01:41 AM
08/02/18 01:41 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
K - member if a 440 or 426
Transmission depending on actual motor
Rear End based on options
Body frame structure based on options
leaf springs based on options
torsion bars based on options
brakes based on options
etc
you really need to refine your question and then we can denote specific differences
Re: Difference between small block and big block [Re: 1fastrunner] #2530330
08/02/18 02:42 AM
08/02/18 02:42 AM
AndyF Offline
AndyF  Offline
Almost everything that interfaces with the engine is different. Throttle cables, hoses, wiring harness, exhaust, transmission, etc.
If you ever swap a big block for a small block you'll find out that almost everything needs to be changed or modified in some manner.
Re: Difference between small block and big block [Re: 1fastrunner] #2530369
08/02/18 09:36 AM
08/02/18 09:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By 1fastrunner
Hi,
Duster never came with a big block.
Re: Difference between small block and big block [Re: JohnRR] #2530385
08/02/18 10:06 AM
08/02/18 10:06 AM
I guess it was worded a little weird. You have answered my question though. I was mainly looking for differences in components besides the engine and transmission.
Re: Difference between small block and big block [Re: 1fastrunner] #2531383
08/04/18 04:33 AM
08/04/18 04:33 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Maybe try less of this....
Re: Difference between small block and big block [Re: Kern Dog] #2532115
08/06/18 12:19 AM
08/06/18 12:19 AM
You are on the right track...but the stuff was better than that.
Re: Difference between small block and big block [Re: 1fastrunner] #2532123
08/06/18 12:50 AM
08/06/18 12:50 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Okay.....
Re: Difference between small block and big block [Re: 1fastrunner] #2532156
08/06/18 06:33 AM
08/06/18 06:33 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
T bar thickness
Sway bar thickness ( not allways )
Radiator core support opening
Then some other stuff like differential, but some HP SBs could get same diff than some BBs
Rest is the same.
Re: Difference between small block and big block [Re: 1fastrunner] #2532270
08/06/18 01:38 PM
08/06/18 01:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would go the other way of things that would be the same. Starter wires, throttle cable, gas line, trans mount, gear shifter.
