Battery suggestions #2531513
08/04/18 03:20 PM
08/04/18 03:20 PM
Illinois
Mopar_Ray Offline OP
Illinois
Looking for a new battery, 1970 Challenger RB 505 stroker about 12:1 compression that doesn’t get driven much, more of a strip car. Battery is located in the trunk, so weight is not much of a problem. What have you had good luck with?
Re: Battery suggestions [Re: Mopar_Ray] #2531519
08/04/18 03:42 PM
08/04/18 03:42 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I use the red Optima battery in my Duster...no problems yet. up
Or...try Interstate..they are good also.
Plymouth Makes It!
Re: Battery suggestions [Re: RoadRunnerLuva] #2531534
08/04/18 04:07 PM
08/04/18 04:07 PM
Illinois
Illinois
I had an Optima yellow top that never seemed to hold a change very long. I will check on interstate.
Re: Battery suggestions [Re: Mopar_Ray] #2531553
08/04/18 05:14 PM
08/04/18 05:14 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Optima red in the street Duster's trunk, 2 regular Group 27s in the race Duster's trunk. All are in cases. Zero problems with either.
Optima's probably the wiser choice, never had one gas off or leak or corrode its terminals.
Re: Battery suggestions [Re: Mopar_Ray] #2531570
08/04/18 06:06 PM
08/04/18 06:06 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
red optima is the best battery I've ever used.
Re: Battery suggestions [Re: Mopar_Ray] #2531686
08/04/18 11:10 PM
08/04/18 11:10 PM
BlueRacer69 Offline
BlueRacer69  Offline
red top optima battery here also.
Re: Battery suggestions [Re: Mopar_Ray] #2531764
08/05/18 01:51 AM
08/05/18 01:51 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Red top and the Optima battery charger.
