AAR Cuda' 8 3/4 third member paint stamp help needed #2531191
08/03/18 09:11 PM
08/03/18 09:11 PM
Akron, ohio
76orangewagon Offline OP
Akron, ohio
I have a nice original low mileage AAR Cuda 8 3/4 third member I am getting ready to rebuild to use in my 1971 Cuda since I can't seem to find a correct date coded 71' housing to match my 430 SPD. There are lots of paint daubs and markings I have found but there is one white paint stamp on the pinion barrel up near the yoke I can't figure out. Any help would be greatly appreciated.
Re: AAR Cuda' 8 3/4 third member paint stamp help needed [Re: 76orangewagon] #2531196
08/03/18 09:20 PM
08/03/18 09:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Soak it in Evapo-Rust.
Pull it out & photograph every paint detail every 30 minutes or so.
What you come to see may amaze you.
Re: AAR Cuda' 8 3/4 third member paint stamp help needed [Re: Alaskan_TA] #2531204
08/03/18 09:40 PM
08/03/18 09:40 PM
Akron, ohio
Akron, ohio
This is after soaking it Evaporust and removing several layers of cheap paint overs to get to it, it was totally un-readable before(see pics below). I don't think it can get clearer, I think it just got applied very sloppy and I just can't make it out.
Re: AAR Cuda' 8 3/4 third member paint stamp help needed [Re: 76orangewagon] #2531360
08/04/18 02:26 AM
08/04/18 02:26 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It looks like a date 10something
and then they stamped an H or and M over it
Re: AAR Cuda' 8 3/4 third member paint stamp help needed [Re: 76orangewagon] #2531381
08/04/18 04:19 AM
08/04/18 04:19 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
On the left side.. like this daub.. i have seen a letter with a paint daub many times..
Re: AAR Cuda' 8 3/4 third member paint stamp help needed [Re: 76orangewagon] #2531384
08/04/18 04:45 AM
08/04/18 04:45 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
3.91 AAR & 3.91 T/A
