Re: 1968 Dart 383 Steering
[Re: TMBOOTS]
#2530791
08/03/18 01:04 AM
08/03/18 01:04 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
..I feel my steering bar should drop down a little more. Why do you feel or think that bar should drop down a little more? I have a original H code 1969 Dart GTS, those 383 motors, 1967 to 1969 A body only, came with a special oil pan, are you aware of that?
[Re: Cab_Burge]
#2530814
08/03/18 03:02 AM
08/03/18 03:02 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
..I feel my steering bar should drop down a little more. Why do you feel or think that bar should drop down a little more? I have a original H code 1969 Dart GTS, those 383 motors, 1967 to 1969 A body only, came with a special oil pan, are you aware of that? You need the pan. Vans Auto sells a reproduction 893 pan and pickup
Abe Lincoln
[Re: TMBOOTS]
#2530910
08/03/18 12:22 PM
08/03/18 12:22 PM
CrazyD
I bought an NOS in the box '383' Pitman arm #3004809 years ago, and attempted a comparison to the standard Pitman #2835745. Clamped splined ends to flat surface. Splined ends were clocked identically at the larger indexing spline. Probably not useful info, but attached photos illustrate the subtle differences in bends.
