Page 2 of 4 1 2 3 4
Re: Tubular K-frames ? [Re: 383man] #2529329
07/30/18 11:32 PM
07/30/18 11:32 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A friend of mine (Who has never been smart about money) bought a kit from Magnum Farce for his 64 Valiant. It was one that required he weld in reinforcement pipes that run from the firewall (Thin sheet metal) to the frame rail (Thicker sheet metal). It came with a tab to weld to the shock mount to add reinforcement/support since all the suspension load was now concentrated into the frame rails. He got the kit including a manual steering rack and 11" disc brakes for just under $5000 shipped. He already had 11" brakes from a 73 Dart but they could not be used since the kit uses a different spindle. He now has less suspension travel, a wider turning radius and $5000 less money to spend on hookers and blow.
Re: Tubular K-frames ? [Re: 383man] #2529344
07/30/18 11:47 PM
07/30/18 11:47 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Re: Tubular K-frames ? [Re: 383man] #2529377
07/31/18 01:35 AM
07/31/18 01:35 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
As I said I like the stock torsion bar setup alot as does my brother but he don't want to trust it on this car. I wanted opinions because I have only ever run the stock front end and he has only had different front ends on race cars. I asked for opinions and I appreciate all the opinions both negative and positive. Thanks again for all the replys. Ron
Re: Tubular K-frames ? [Re: 383man] #2529387
07/31/18 02:48 AM
07/31/18 02:48 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Cut out the TB crossmember, install a new one, much easier. Plenty of donner cars if you want original.
Re: Tubular K-frames ? [Re: bigdad] #2529401
07/31/18 08:03 AM
07/31/18 08:03 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Originally Posted By bigdad
On my 67 , I installed a new set up from
Carl Gerst
http://gerstsuspensions.com/products/
Nice piece all well built, car drives great .. its a race car so ..
Neither of them are "cheap"
I have one of these kits sitting in the floor waiting to be installed in my cousins 74 Duster, it's a street/strip car, big block with TTI headers, anxious to see the fit and how much clearance we gain... maintenance on this thing is a "flipping" nightmare panic going to weigh everything as it comes apart to see how much weight it saves also...more to come up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Tubular K-frames ? [Re: Stanton] #2529415
07/31/18 09:45 AM
07/31/18 09:45 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Originally Posted By Stanton
My guess is bigdad would buy square wheels if someone made them.
There are thousands, if not millions, of companies out there who try to build a better mousetrap. They will actually invent benefits of their product even though they're aware of the genius of the original design. All to make a buck. Square wheels ... sure, the ride is rough but the car won't roll when its parked !!!
If you want a coilover front end that bad, go buy a car that was designed for it - a Ford or Chevy.
You can insult me all you want , fact is my stuff always rides, drives, works retains great values win awards, end up in magazines ..
Dodges don't have coil over suspension ? maybe you should look into what they have built since 1962
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tubular K-frames ? [Re: 383man] #2529459
07/31/18 11:53 AM
07/31/18 11:53 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'm not opposed to tubular systems and coil overs. They offer some very distinct advantages over the stock stuff and if you can utilize those benefits, then they can be a great system that provides the user with numerous benefits. Its just that a lot of users seem to not know about or care for the benefits of these systems and buy them on simply on the perception of being "modern" and therefore better than something developed 60 years ago.
In all honesty, if you want to use them go for it. There is no practical reason to own a 707 hp intercooled, supercharged Hemi either, but we buy them. Being a hot-rodder isn't always about purely being logical. Sometimes passion is a factor too.
Re: Tubular K-frames ? [Re: bigdad] #2529462
07/31/18 12:03 PM
07/31/18 12:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think someone doesn't know the difference between coil over and MacPherson strut, which is probably a good reason to not pay attention to suspension advice from that person.
Don't be the exception.
Re: Tubular K-frames ? [Re: 383man] #2529472
07/31/18 12:29 PM
07/31/18 12:29 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
A strut is any suspension component with the ability to support sideways loads not along its axis of compression therefore eliminating any need for an upper control arm.
A coilover is when you combine a spring with a strut, making it a type of strut.
A McPherson is a type of coilover
Its kinda like asking what is the difference between a dog and a German Sheppard.
Re: Tubular K-frames ? [Re: 383man] #2529481
07/31/18 12:53 PM
07/31/18 12:53 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a AlterKation on my 70' Challenger. No complaints I love everything about it. I only went with it because it was free (long story) and to free up space for big tube Hemi Headers & so I could run a flat bottom 10 quart dragster type oil pan on the street & not the usual deep sump pans the hit everything..
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Tubular K-frames ? [Re: 383man] #2529502
07/31/18 01:47 PM
07/31/18 01:47 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
So how many of these kits are actually designed to do anything more than go straight real fast on a smooth surface and then make a very reduced speed turn onto the return road?
Kevin
Re: Tubular K-frames ? [Re: 383man] #2529506
07/31/18 01:55 PM
07/31/18 01:55 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Don't forget all tubular K-members are illegal for road use. So as long as he doesn't want to drive it on the street, he's all good.
Re: Tubular K-frames ? [Re: Devil] #2529523
07/31/18 02:18 PM
07/31/18 02:18 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Please show me the statutes, I have never been able to find them... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Tubular K-frames ? [Re: 383man] #2529552
07/31/18 03:04 PM
07/31/18 03:04 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Advantages are more clearance for headers, possibility of going with rack and pinion steering, and move engine back/larger oil pan. Downside is that the top of the shock tower needs to have some type of modification to bring loads down to frame rail. Either additional bars or, as I think I have seen in the past, plates that weld on to frame rails up to top of shock tower. I'd also triangulate the shock towers to the cowl to resist twist. I can't help with costs as I don't have one, but for simple street driving, I would replace torsion bar cross member. Add frame connectors, stiffen lower control arms, and maybe tubular upper to add some caster, along with all new bushings and call it a day. Just my twocents
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Tubular K-frames ? [Re: Rhinodart] #2529556
07/31/18 03:07 PM
07/31/18 03:07 PM
dogdays Offline
dogdays  Offline
Yeah, don't give me that crap! They're not immoral or fattening either. It's easy to make a blanket statement having done no research.
OP, I understand your situation better now you have explained it. My earlier point was directed more to those who think they need to get rid of an outmoded system. That dog won't hunt. But your brother seems willing to spend the money and so more power to him. There were I believe at least three reliable companies named.
Now on to the "loading of the suspension" ridiculous argument. The entire force that pushes down on the wheel pushes up on the chassis AT THAT POINT. There's no way around this fact. The problem with coil sprung conversions is that some of them mount the top of the coilover to the inner fender, which was NOT designed to carry the load. So if the new suspension system has a loop or other fixture for the top of the coilover, this argument dies. Assuming the new K-frame mounts the same way as the old K-frame, the load is transmitted in exactly the same way as the original suspension.
I know some of you are not going to believe me but it isn't a matter of belief or how you "feel". It's just basic engineering.
The torsion bar crossmember is very important to the torsion bar car because it connects the moments exerted by the two bars, which cancel each other out as they are added.
My 1993 Chevy K2500 4WD Suburban has a torsion bar setup that is very much like the original Chrysler design. There are literally millions of trucks running around with this front end.
A MacPherson strut has the spindle rigidly attached to an extension of the shock absorber. It may be a coilover, but all coilovers are not MacPherson struts.
The MacPherson strut has one very serious design flaw. When the vehicle rolls, the strut and tire roll with it. This decreases the amount of grip the tire can have, in most cases. The only way around that is to have the tire set up with excessive negative camber so when the car rolls, the tire rotates into better contact with the road. This is impractical for the street because of tire wear.
The double A-arm or unequal length A-arm suspension is superior because it can be designed to compensate for the vehicle rolling. It can be suspended by coilovers, coil springs between the A-arms, torsion bars, or springs and shocks pressing down on the upper A-arm. That is mostly due to packaging.
R.
Re: Tubular K-frames ? [Re: dogdays] #2529574
07/31/18 03:42 PM
07/31/18 03:42 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is an older AlterKtion on a 67 Barracuda that I currently have. The coil overs go where the round bar is between the lower control arm and the vertical member, the entire load on the coil overs is on the vertical member while the k-frame itself is bolted to the regular mounting spots on the frame rails. I don't see any issues with this design. shruggy
A-Body's RULE!
Re: Tubular K-frames ? [Re: Rhinodart] #2529586
07/31/18 03:59 PM
07/31/18 03:59 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Says right in the instructions for all the tubular setups. "For Off-Road use only". That way when they fail, they aren't libel.
Re: Tubular K-frames ? [Re: Devil] #2529593
07/31/18 04:22 PM
07/31/18 04:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Well that in itself does not make them "illegal", that is just lawyer speak for CYA... work
A-Body's RULE!
Re: Tubular K-frames ? [Re: Devil] #2529594
07/31/18 04:22 PM
07/31/18 04:22 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Stop with the BS! Alterkations says this:
"Disclaimer
Reilly MotorSports, Inc. cannot control how this product is installed or used. By purchasing this product, the buyer/end user assumes all risks associated with its use and agrees to having the proper skills for it's
installation. Reilly MotorSports Inc. and its suppliers will not be held responsible, liable or accountable for any injury, damage, loss, penalties, or fines that occur from using this product in any manner."
https://www.reillymotorsports.com/files/attachments/16247/AlterKtion_Instructions_2016.pdf
Re: Tubular K-frames ? [Re: 383man] #2529617
07/31/18 05:01 PM
07/31/18 05:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
"Disclaimer
And any lawyer that just passed the bar could fight this and win. There isn't a disclaimer on the planet that can't be fought and won if negligence by the manufacturer can be proven.
Page 2 of 4 1 2 3 4
