Page 170 of 180 1 2 168 169 170 171 172 179 180
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529084
07/30/18 03:26 PM
07/30/18 03:26 PM
State of confusion
Thumperdart Offline OP
State of confusion
FMJ.....I'm wanting to ditch my Billet Specialties and go to steel LOOKING alum. wheels with hub caps, don't you have a guy that makes these? thumbs
Re: Real world weight loss program and it` cost.......... [Re: cdwmotorsports] #2529088
07/30/18 03:37 PM
07/30/18 03:37 PM
fullmetaljacket Offline
CDW
My oil pump is as visible as any other B-body oil pump on a Wedge. I was just so intrigued by the fact that Chrysler went ahead with an aluminum version back then for their A-990's, but how long could those pumps survive constant service now.
I am leaning towards the Milodon unit only because it should be eligible for constant service on the street. Make a note that my car is a weekend street car, not a daily driver. but sees plenty of traffic during those excursions aside from the occasional track visit.
I can get away with some massaging and masquerading with paints to make Milodon disappear to the naked eye.
Nowadays the alloys and processing is so much better and made for rigorous use. I know someone running aluminum Max Wedge long horn exhaust manifolds, but this car is a purpose built car only. Plus these recent manifolds were casted in a T-356 alloy to withstand the intense heat at the ports faces.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529098
07/30/18 03:46 PM
07/30/18 03:46 PM
Thumper
No, I made only the aluminum disc cover that makes the standard Auto-drag centerlines look like a naked steel wheel. Some where on this long thread are the pics to the wheels during the process.
The Auto-drag Centerlines with the round rivets holding them together have the most stock looking ridges or crevices that are on a steel wheel, so they became the candidates for the main part of the wheels. When Special K and I both had a lightbulb moment to make the disc cover, I had a local machine shop spin 'em for me on their lathe. They mount on the wheel along with the lugs when installing the wheels themselves.
Nice and light.
PS: There is a guy in the F.A.S.T class posse that is rumored to have made steel looking aluminum wheels that mimic the Chevrolet steel wheels. But those are from an independent source.
I wish someone made the patterns and road testing rigors that a wheel has to go through, but that I$ all about $$$$$$. I know a vast majority of guys aside from the F.A.S.T and PURE stock guys would spring for them. I know I would be first on line with bribe money. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529128
07/30/18 04:32 PM
07/30/18 04:32 PM
State of confusion
State of confusion
Ok, thankxxx............what are we talking here in terms of added weight going from my alum. 10's in the rear and 3 1/2 fronts and say 4- 4 1/2 steelies up front any idea? thumbs
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529145
07/30/18 05:13 PM
07/30/18 05:13 PM
My stock steel 4-1/2 wheels were 15-1/2" Lbs each.
The Auto drag centerline 3-1/2" wheels were 11 lbs each.
My stock steel "Ramcharger" 15" X 8" wheels were 23 Lbs each.
My Auto drag Centerline 15" X 8" were 14-1/2 Lbs each.
On the same note, it all boils down to tire selection since some tires are much heavier than others, even for the front narrow types. For instance, my 60's vintage "Super Stock Formula #1" front runners were 23 Lbs each. Heavier than the d@mm steel wheel itself, where as the Moroso drag tires were 13-1/2 Lbs each.
Made a big difference.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529146
07/30/18 05:16 PM
07/30/18 05:16 PM
State of confusion
State of confusion
I'm pretty much done track racing and want the stealthy look for late night stuff so not as bad as I thought and will run slicks and race fronts anyhow.......... thumbs
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529188
07/30/18 06:48 PM
07/30/18 06:48 PM
TD.
For a number of years, I ran the centerlines just plain jane painted gloss black. At least that kept the prying eyes away for a short time till they were seen in broad day light.
If I ever make a few sets of the cover, "don't hold your breath" I'll send you a complimentary set to try out. That Dart with its body color would look mean with blacks all around.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529192
07/30/18 06:51 PM
07/30/18 06:51 PM
As a safety reminder, keep those 2 ply fronts clear from any pot holes or curves as the side walls are thin, hence why they are lighter than most other 4 ply tires. When I ran the Moroso Drag Specials on the street, I made sure to be extra, extra careful with irregular road conditions.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529195
07/30/18 06:54 PM
07/30/18 06:54 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
It'd take a bit of searching but I do recall that post from FMJ about the spinning of the "stock" wheels
About halfway down is the first mention...
Stock wheels
By the way that was 5 minutes of searching... lol
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529199
07/30/18 07:01 PM
07/30/18 07:01 PM
Martinsville, IN
Martinsville, IN
What cracks me up is Jegs still sells that ugly A$$ wheel
I like them so much better the way FMJ modded them
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529213
07/30/18 07:42 PM
07/30/18 07:42 PM
State of confusion
State of confusion
Originally Posted By fullmetaljacket
TD.
That would rock but I get it and really want black hub capped stealth look and 9 second et's to boot............ drive
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529216
07/30/18 07:46 PM
07/30/18 07:46 PM
Man you're asking for everything and plus the girl. LOL
Re: Real world weight loss program and it` cost.......... [Re: cdwmotorsports] #2529220
07/30/18 07:51 PM
07/30/18 07:51 PM
CDW
I believe the Auto drags are Centerlines best sellers of all time, or at least at one time.
I used to like the super tricks that the early Pro-stocks used with the bolts holding the two halves instead of the rivets.
I wonder how many cats would buy a stock looking aluminum wheel?
I mean, they've already made a billet rally wheel, (Heavy) why not produce what Chrysler was best known for, lightweight suited steelies.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529221
07/30/18 07:53 PM
07/30/18 07:53 PM
Martinsville, IN
Martinsville, IN
I'd buy them as long as the poverty caps still fit the aluminum version.
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529260
07/30/18 09:37 PM
07/30/18 09:37 PM
here's the spun disc cover again topside. It hides those ugly rivets and brings the wheel closer to stock look.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529262
07/30/18 09:40 PM
07/30/18 09:40 PM
Here's the back side in raw form. Disc was made without the lug stud holes. I placed onto wheel surface, carefully centered and traced out the holes.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529264
07/30/18 09:41 PM
07/30/18 09:41 PM
Spinning wheels, she so fine.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529269
07/30/18 09:44 PM
07/30/18 09:44 PM
Suspect wheel in a certain class action suit.
I must say, this is really stealth if indeed it is of a light alloy. Those guys have free open reign as far as what they can invent under the midnight oil. Love it.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2529276
07/30/18 09:54 PM
07/30/18 09:54 PM
State of confusion
State of confusion
I'm solidly in the 9's now and I don't see 40-50 lbs changing that much but we will find out when I make the change and hit the track for a "real world" test............ biggrin
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2529280
07/30/18 09:59 PM
07/30/18 09:59 PM
You should be in good territory even with the steel wheels.
