Re: Tubular K-frames ?
[Re: 383man]
#2529329
07/30/18 11:32 PM
07/30/18 11:32 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
A friend of mine (Who has never been smart about money) bought a kit from Magnum Farce for his 64 Valiant. It was one that required he weld in reinforcement pipes that run from the firewall (Thin sheet metal) to the frame rail (Thicker sheet metal). It came with a tab to weld to the shock mount to add reinforcement/support since all the suspension load was now concentrated into the frame rails. He got the kit including a manual steering rack and 11" disc brakes for just under $5000 shipped. He already had 11" brakes from a 73 Dart but they could not be used since the kit uses a different spindle. He now has less suspension travel, a wider turning radius and $5000 less money to spend on hookers and blow.
[Re: bigdad]
#2529401
07/31/18 08:03 AM
07/31/18 08:03 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
On my 67 , I installed a new set up from Carl Gerst http://gerstsuspensions.com/products/Nice piece all well built, car drives great .. its a race car so .. Neither of them are "cheap" I have one of these kits sitting in the floor waiting to be installed in my cousins 74 Duster, it's a street/strip car, big block with TTI headers, anxious to see the fit and how much clearance we gain... maintenance on this thing is a "flipping" nightmare going to weigh everything as it comes apart to see how much weight it saves also...more to come
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: Stanton]
#2529415
07/31/18 09:45 AM
07/31/18 09:45 AM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My guess is bigdad would buy square wheels if someone made them.
There are thousands, if not millions, of companies out there who try to build a better mousetrap. They will actually invent benefits of their product even though they're aware of the genius of the original design. All to make a buck. Square wheels ... sure, the ride is rough but the car won't roll when its parked !!!
If you want a coilover front end that bad, go buy a car that was designed for it - a Ford or Chevy.
You can insult me all you want , fact is my stuff always rides, drives, works retains great values win awards, end up in magazines .. Dodges don't have coil over suspension ? maybe you should look into what they have built since 1962
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2529462
07/31/18 12:03 PM
07/31/18 12:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can insult me all you want , fact is my stuff always rides, drives, works retains great values win awards, end up in magazines .. Dodges don't have coil over suspension ? maybe you should look into what they have built since 1962 I think someone doesn't know the difference between coil over and MacPherson strut, which is probably a good reason to not pay attention to suspension advice from that person.
[Re: 383man]
#2529472
07/31/18 12:29 PM
07/31/18 12:29 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
A strut is any suspension component with the ability to support sideways loads not along its axis of compression therefore eliminating any need for an upper control arm.
A coilover is when you combine a spring with a strut, making it a type of strut.
A McPherson is a type of coilover
Its kinda like asking what is the difference between a dog and a German Sheppard.
[Re: 383man]
#2529481
07/31/18 12:53 PM
07/31/18 12:53 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I have a AlterKation on my 70' Challenger. No complaints I love everything about it. I only went with it because it was free (long story) and to free up space for big tube Hemi Headers & so I could run a flat bottom 10 quart dragster type oil pan on the street & not the usual deep sump pans the hit everything..
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Devil]
#2529523
07/31/18 02:18 PM
07/31/18 02:18 PM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Don't forget all tubular K-members are illegal for road use. So as long as he doesn't want to drive it on the street, he's all good. Please show me the statutes, I have never been able to find them...
JB Rhinehart, Realist
A-Body's RULE!
[Re: 383man]
#2529552
07/31/18 03:04 PM
07/31/18 03:04 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Advantages are more clearance for headers, possibility of going with rack and pinion steering, and move engine back/larger oil pan. Downside is that the top of the shock tower needs to have some type of modification to bring loads down to frame rail. Either additional bars or, as I think I have seen in the past, plates that weld on to frame rails up to top of shock tower. I'd also triangulate the shock towers to the cowl to resist twist. I can't help with costs as I don't have one, but for simple street driving, I would replace torsion bar cross member. Add frame connectors, stiffen lower control arms, and maybe tubular upper to add some caster, along with all new bushings and call it a day. Just my
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Rhinodart]
#2529556
07/31/18 03:07 PM
07/31/18 03:07 PM
dogdays
Yeah, don't give me that crap! They're not immoral or fattening either. It's easy to make a blanket statement having done no research.
OP, I understand your situation better now you have explained it. My earlier point was directed more to those who think they need to get rid of an outmoded system. That dog won't hunt. But your brother seems willing to spend the money and so more power to him. There were I believe at least three reliable companies named.
Now on to the "loading of the suspension" ridiculous argument. The entire force that pushes down on the wheel pushes up on the chassis AT THAT POINT. There's no way around this fact. The problem with coil sprung conversions is that some of them mount the top of the coilover to the inner fender, which was NOT designed to carry the load. So if the new suspension system has a loop or other fixture for the top of the coilover, this argument dies. Assuming the new K-frame mounts the same way as the old K-frame, the load is transmitted in exactly the same way as the original suspension.
I know some of you are not going to believe me but it isn't a matter of belief or how you "feel". It's just basic engineering.
The torsion bar crossmember is very important to the torsion bar car because it connects the moments exerted by the two bars, which cancel each other out as they are added.
My 1993 Chevy K2500 4WD Suburban has a torsion bar setup that is very much like the original Chrysler design. There are literally millions of trucks running around with this front end.
A MacPherson strut has the spindle rigidly attached to an extension of the shock absorber. It may be a coilover, but all coilovers are not MacPherson struts. The MacPherson strut has one very serious design flaw. When the vehicle rolls, the strut and tire roll with it. This decreases the amount of grip the tire can have, in most cases. The only way around that is to have the tire set up with excessive negative camber so when the car rolls, the tire rotates into better contact with the road. This is impractical for the street because of tire wear.
The double A-arm or unequal length A-arm suspension is superior because it can be designed to compensate for the vehicle rolling. It can be suspended by coilovers, coil springs between the A-arms, torsion bars, or springs and shocks pressing down on the upper A-arm. That is mostly due to packaging.
R.
[Re: Rhinodart]
#2529586
07/31/18 03:59 PM
07/31/18 03:59 PM
Posts: 10,501 Chicago, Illinois
Devil
Chicago, Illinois
Don't forget all tubular K-members are illegal for road use. So as long as he doesn't want to drive it on the street, he's all good. Please show me the statutes, I have never been able to find them... Says right in the instructions for all the tubular setups. "For Off-Road use only". That way when they fail, they aren't libel.
[Re: Devil]
#2529594
07/31/18 04:22 PM
07/31/18 04:22 PM
Posts: 3,078 N.W. Florida
Fat_Mike
N.W. Florida
Stop with the BS! Alterkations says this: "Disclaimer Reilly MotorSports, Inc. cannot control how this product is installed or used. By purchasing this product, the buyer/end user assumes all risks associated with its use and agrees to having the proper skills for it's installation. Reilly MotorSports Inc. and its suppliers will not be held responsible, liable or accountable for any injury, damage, loss, penalties, or fines that occur from using this product in any manner." https://www.reillymotorsports.com/files/attachments/16247/AlterKtion_Instructions_2016.pdf
[Re: 383man]
#2529617
07/31/18 05:01 PM
07/31/18 05:01 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
"Disclaimer Reilly MotorSports, Inc. cannot control how this product is installed or used. By purchasing this product, the buyer/end user assumes all risks associated with its use and agrees to having the proper skills for it's installation. Reilly MotorSports Inc. and its suppliers will not be held responsible, liable or accountable for any injury, damage, loss, penalties, or fines that occur from using this product in any manner." And any lawyer that just passed the bar could fight this and win. There isn't a disclaimer on the planet that can't be fought and won if negligence by the manufacturer can be proven.
