Re: best way to mark ports on heads ot intakes to port?
[Re: 340SIX]
#2528533
07/29/18 08:08 AM
07/29/18 08:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Is there a question there?
[Re: 340SIX]
#2528712
07/29/18 06:27 PM
07/29/18 06:27 PM
RapidRobert
I make a horizontle swath of Dyken across the top & bottom of the intake & head ports then scribe a horizontle line across the top & bottom of the ports in the dye (+slight porting ahead of time to get the top/bottoms of the ports even, as needed) then at each "end" of the scribed lines a 90 deg turndown in a bit more dykem. so you have an "L" at the end of each horizontle scribed line (I hope that descrip makes sense). Do the same on the intake then I set the intake down on the side gaskets (SB) & at each end of the eng tilt the manifold a bit up/down (side to side) till the lines between the heads & the intake have the same gap on each of the 4 corners. EDIT (SB) May need thicker/thinner side gaskets or even 2 pairs and or elongating the intake mounting holes or intake milling. Mockup dry & go from there.
[Re: RapidRobert]
#2529828
08/01/18 04:38 AM
08/01/18 04:38 AM
Posts: 28,639 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I make a horizontle swath of Dyken across the top & bottom of the intake & head ports then scribe a horizontle line across the top & bottom of the ports in the dye (+slight porting ahead of time to get the top/bottoms of the ports even, as needed) then at each "end" of the scribed lines a 90 deg turndown in a bit more dykem. so you have an "L" at the end of each horizontle scribed line (I hope that descrip makes sense). Do the same on the intake then I set the intake down on the side gaskets (SB) & at each end of the eng tilt the manifold a bit up/down (side to side) till the lines between the heads & the intake have the same gap on each of the 4 corners. EDIT (SB) May need thicker/thinner side gaskets or even 2 pairs and or elongating the intake mounting holes or intake milling. Mockup dry & go from there. Thanks The intake was pro done as well as the heads. But thinking of doing stock 340 exhaust manifolds. When I have done stuff it was silver and easy to mark. I just want to gasket match and clean up the ports best I can. Never done anything other than soft stuff. So this should be an adventure. Here is a shot of the polish work on the heads. And the port work that was done on the intake. I only have 1/3rd the intake outside polished.
![Name: intake2.JPG
ID: 331969 intake2.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/331969/filename/intake2.JPG) ![Name: eddie1.jpg
ID: 331971 eddie1.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/331971/filename/eddie1.jpg)
[Re: 340SIX]
#2529943
08/01/18 12:46 PM
08/01/18 12:46 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
With the engine assembled I use gaskacinch or contact cement to stick the gaskets to the head, just three small dabe about the size of a dime. Make sure the gasket and ports are lined up. Once it's set up I bolt the intake on and scribe a line on the gasket along the top of the intake, also mark each gasket for drivers and passengers side. Then unbolt the intake and remove the gasket, some contact cements may require a razor blade scraper to aid in removal. Then bolt the gasket to their respective sides of the intake making sure the scribe line matches the intake, then scribe the ports. I just use a black permanent marker around the ports before I scribe around the gasket.
[Re: 340SIX]
#2529976
08/01/18 01:39 PM
08/01/18 01:39 PM
RapidRobert
But thinking of doing stock 340 exhaust manifolds. Lookup acid porting exhaust manifolds on utube. good gains to be had.
[Re: 340SIX]
#2530442
08/02/18 12:49 PM
08/02/18 12:49 PM
Posts: 2,849 Connecticut
FurryStump
Connecticut
It’s been a long time, but IIRC isn’t this a street car? What are your performance goals. I did notice a performance gain port matching and cleaning up the exhaust manifold entries a touch, but nothing big. I know of cars running 11.7 with just being port matched. With a free flowing intake side you could be low 11’s. Acid or extrude hone not really worth it unless you are shooting for that last couple of hp.
[Re: 340SIX]
#2530515
08/02/18 03:08 PM
08/02/18 03:08 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
Dykem
