Re: intake exhaust block off?
[Re: marcjames]
#2528351
07/28/18 05:54 PM
07/28/18 05:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I just fill the ports with JB Weld, about a 1/2" thick "plug" and never had one burn thru.
Just mix up a batch of JB, pour it in one crossover port, put masking tape across the port and prop the intake so that the surface is flat on the table and let it set. Gravity will let the epoxy flow down too the tape and seal the port. Once that side is setup, do the other side. Done. On an LA I generally use one, two part kit of JB Weld per side.
[Re: marcjames]
#2529555
07/31/18 03:06 PM
07/31/18 03:06 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
marcjames --> I agree with RJS BlueRacer69 --> the hot exhaust gases are not even close to being hot enough to burn through the valley pan "block off", thin metal.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: marcjames]
#2529755
07/31/18 10:24 PM
07/31/18 10:24 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
At one time I'd fill the intake with duroglass and use the block off gasket. Overkill, gasket works fine.
Have a great day Iowan
"obsolete is neat"
[Re: marcjames]
#2529764
07/31/18 11:02 PM
07/31/18 11:02 PM
Posts: 3,916 usa
lewtot184
usa
[Re: marcjames]
#2529787
08/01/18 12:09 AM
08/01/18 12:09 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Wow, a lot of work some people put into this. For my small block I used thin gauge sheet of hobby brass (nothing special) from Lowes. I cut it a little bigger than the opening in the gasket, stuck it on with RTV to keep it in place while I torqued down the intake and was done. Years later pulled off the intake, wiped off the little brass plates and they looked like the day I installed them. In fact I reused them when I put the motor back together.
Combustion does generate water. If your block offs are burning through, its probably more like they rusted through and got sooty looking once the hole was already there.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#2529805
08/01/18 01:36 AM
08/01/18 01:36 AM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
https://www.summitracing.com/search/part-type/wheels/department/wheels-tires/wheel-material/steel?N=4294920860%2B4294950865%2B4294920356%2B4294566455%2B4294920856&SortBy=Default&SortOrder=Ascending
Wow, it’s not rocket science. Just buy the valley pan with the block off.
Abe Lincoln
[Re: dart4forte]
#2529874
08/01/18 10:33 AM
08/01/18 10:33 AM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
Wow, it’s not rocket science. Just buy the valley pan with the block off. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) No need to complicate the crap out of it.
