heater core replacement 04 Jeep GC #2527689
07/27/18 12:55 AM
07/27/18 12:55 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
My GF AC evaporator core in her 04 Jeep Grand Cherokee went out. Apparently you have to remove the entire dash and interior in order to get to it.
I told her to go ahead and replace the heater core as it is right there, and the part is not that much.
The mechanic and the parts guy we trust says, the factory heater core is better than the aftermarket ones and not to replace it.
Are the aftermarket heater cores junk? and we should run with the 15 year old orig, or replace it with a new aftermarket one?
Oddly enough the mechanic said to NOT get a factory evaporator as those are junk (and the aftermarket ones are better), but he appears to have the opposite opinion on the heater core?
This is approaching a $1k job, so don't want to do it twice to replace the heater core later....
Anyone have any thoughts?
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527740
07/27/18 08:29 AM
07/27/18 08:29 AM
Mass
charge70 Online content
charge70  Online Content
Mass
The aftermarket cores are not as good as the factory ones.I can understand wanting to replace it as you will have the heater box out.What is the difference in price from the factory core to the aftermarket? At work,I allways push for the factory stuff as it is usually better but sometimes the cost prohibits that.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527748
07/27/18 09:50 AM
07/27/18 09:50 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I don't know what the factory heater core costs; he recommended leaving the old one in. oddly enough he recommended NOT getting the factory evaporator as for some reason he thinks the aftermarket ones are better.
Kind of confused?
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527753
07/27/18 10:00 AM
07/27/18 10:00 AM
Mass
Mass
Sometimes the o.e. stuff had problems and the aftermarket parts will be redesigned to correct that but not allways.I would price the o.e. heater core and decide from there.I've never put a heater core in one of those vehicles but that doesn't mean it won't ever fail.
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527754
07/27/18 10:01 AM
07/27/18 10:01 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Go buy the factory mopar one and hand it to them and then tell them to install it.
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527772
07/27/18 10:28 AM
07/27/18 10:28 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I haven't done one in several years now. But I had really good luck with Mopars value line of heater / ac cores .
They were priced competitively with the aftermarket cores
But either way, I would do both while it was apart
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527812
07/27/18 11:50 AM
07/27/18 11:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Installed lots of after market cores and evaps at the shop.Never had a problem with them.Typically we only used factory when customer asked for it.On those like mini vans Durangos etc we always replcade both unless customer didnt want it.Then there was no warranty on the old stuff not going bad.Kind of like changing a water pump when you change a timing belt.We typicall used NAPA or Advance cores.Rocky
Chrysler Firepower
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527820
07/27/18 12:10 PM
07/27/18 12:10 PM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
When I did the evaporator in my Durango, I also replaced the heater core with an aftermarket and it only lasted a couple of years. I did paint the evaporator as it looked like the pin holes that developed because of the water and raw aluminum. Check to see how the blower motor is mounted. On my '98 Durango you had to remove the heater core box to replace it which I again had to remove the dash. I started getting good at removing the dash in that vehicle.
Re: heater core replacement 04 Jeep GC [Re: 6T6Cuda] #2527833
07/27/18 12:32 PM
07/27/18 12:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The aftermarket heater cores on the Ram were problematic from what I was reading. Don`t know about the Jeep.
