How to clean up Alternator for rebuild?
#2527652
07/26/18 11:06 PM
07/26/18 11:06 PM
Posts: 306 NY
LTLBEE
NY
I want to rebuild my original date coded alternator for my 70 cuda. The internals will all be replaced because they are rusted together, so I will be using just the two case halves. What do the rebuilders/restorers use to clean up the crud on the aluminum case without removing the date codes. Beadblast, Sandblast, Walnut shells? I want it to look as original as possible when done without painting it.
Re: How to clean up Alternator for rebuild?
[Re: LTLBEE]
#2529246
07/30/18 09:10 PM
07/30/18 09:10 PM
Posts: 12,075 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
With a glass bead cabinet, the pressure can be turned way down so that it takes a long time to blast the crud away, but it leaves the surface very clean and about the right color and texture. But the only way it will stay that way is to coat it. I use clear with flattening agent. It takes some experimenting to get the right amount of flat and it probably does not look 100% OE correct. But it looks very much like OE to most of us. And stays that way.
Master, again and still
