Difference between E-Street and RPM Heads ? #2527458
07/26/18 04:28 PM
07/26/18 04:28 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
What is the difference between the Edelbrock E-Street and RPM heads?
This is for a Big Block, and looking at the 75cc versions of each.
It looks like they both use the #5792 Valve springs.
Do they use different quality valves?
Not sure why the RPM is $556 more expensive per pair?
Re: Difference between E-Street and RPM Heads ? [Re: 451Mopar] #2527462
07/26/18 04:36 PM
07/26/18 04:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Powdered metal vs ductile iron seats, and slightly different valves.
That’s it.
The minuscule amount of blending done on an rpm doesn’t do anything.
