Re: Intake recommendations please
[Re: AndyF]
#2527407
07/26/18 02:55 PM
07/26/18 02:55 PM
BradH
Do you have an intake on the engine now? If so, just use it. Otherwise I agree with dogdays. A Performer RPM or a Holley Street Dominator. Would a Sniper EFI setup be "happier" (or more effective) on a single-plane intake or a dual-plane? I suppose I'm thinking in terms of fuel distribution...
[Re: 68rtcharger]
#2527409
07/26/18 03:05 PM
07/26/18 03:05 PM
Posts: 228 TN
68rtcharger
TN
Thanks dogdays for the reply!!
Oh, and yes its finding it way under the Charger hood Engine build is all new, no intake yet
[Re: 68rtcharger]
#2527456
07/26/18 04:26 PM
07/26/18 04:26 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
Stock hood you say? Definitely use the Holley Street Dominator.
[Re: BradH]
#2527466
07/26/18 04:40 PM
07/26/18 04:40 PM
Posts: 31,061 Oregon
AndyF
Do you have an intake on the engine now? If so, just use it. Otherwise I agree with dogdays. A Performer RPM or a Holley Street Dominator. Would a Sniper EFI setup be "happier" (or more effective) on a single-plane intake or a dual-plane? I suppose I'm thinking in terms of fuel distribution... Use a single plane for sure with port injection but throttle body should be similar to carb since the fuel is sprayed above the throttle blades. I used a Performer RPM with my Sniper and it seemed to work just fine. I'm going to try a Trick Flow intake next.
