Re: Race trailer tires, I HATE them! [Re: biff426] #2526825
07/25/18 12:08 PM
07/25/18 12:08 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Originally Posted By biff426
The 16 inch tires will have the same problems. I bought a featherlite with 16 inch tires 3 years and 2 months till the first blow out then on the same trip another blew out. I replaced them and 2 years almost to the day had 1 blow out. I was super anal about pressure I checked it before each trip. I raced NMCA for 5 years and put 40,000 miles on the trailer. The 3rd set of tires were on trailer when I sold it. Trailer tires suck I'm going to try LT 16 inch tires.
some of the big power boat races run a LT tire with good results.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2526843
07/25/18 12:40 PM
07/25/18 12:40 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I blew 2 of the oem Featherlite LT235/85R16 Kumhos, but they were 10 years old. Jock Nicholson tipped me to only use LT tires, that have a complete UTG. It seems very few do.
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2526870
07/25/18 01:30 PM
07/25/18 01:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My new USA made Goodyears have been doing fine for the last 20 months so far. Since we are in the desert we will see how they hold up from this point forward. It has not been unusual for me to start having problems about now. Even vehicle tires do not last near as long out here in the desert SW. When I was on my way home from the dyno Monday it was 121 coming across the desert, I saw my truck tire pressures rise 8lbs..
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2527137
07/25/18 11:18 PM
07/25/18 11:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The lot at work yesterday was 168-180 on the blacktop..... brutal!
Re: Race trailer tires, I HATE them! [Re: Savoy1964] #2527422
07/26/18 03:37 PM
07/26/18 03:37 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Originally Posted By Savoy1964
I'm trying the new Goodyear Endurance - Size: ST225/75R15 will see if they hold up.
Excellent tire. I would bet I put more miles than most here on my trailer and I went with those last year. Wearing great....even the steer tires show no inside wear. I would recommend them highly. Not cheap but well worth the extra dollars.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2527471
07/26/18 04:53 PM
07/26/18 04:53 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By Cab_Burge
I was told by a commercial Cooper tire dealer to always inflate any tire to 5 lbs. above the sidewall rating, he was in Victorville, CA in the Mojave desert near J work
I do that on all my trailer and truck tires, works fine for me except them dang trailer tires coming apart runaway
I looked last night for E or G rated LT 15 inch tires on Summit, I didn't find any and there is no way I'm putting C or D load rated tires on my trailer down
I have weighed the trailer multiple times loaded and unloaded, max weight has been 8640 Lbs. on the axles and adding 700 Lbs. on the rear truck axle while removing 300 Lbs. off the front truck axle with my old Duster work
Is this just the trailer axle weight or total gross truck and trailer?
8600 is a lot of weight on what I'm assuming is a 235/75/15 x 4. If it was a 1/2 ton pickup you would have to have 3500 lbs in the box to weigh that and you'd be surprised to get out of the driveway.
In any case I'd be running the highest load rated LT tire I could get for that size that had a highway speed rating of at least 75 mph.
Trailer tires are for utility trailers that never leave the farm.
Kevin
Re: Race trailer tires, I HATE them! [Re: Twostick] #2527512
07/26/18 06:28 PM
07/26/18 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Buy 4 tire covers AND USE THEM.. I have blown
out 1 tire in all the years of hauling a 43'
enclosed trailer.. mine are 16" (4 tires only)
but are covered... I had 1 cover blow off while
it was parked.. thats been the ONLY tire to blow
but I also buy the best tires(brand names).. sun
light KILLS TIRES
wave
Re: Race trailer tires, I HATE them! [Re: MR_P_BODY] #2527623
07/26/18 10:23 PM
07/26/18 10:23 PM
IN
ahy Offline
ahy  Offline
IN
I always carry a spare but have not had to use it. Better luck I guess. Running far and fast, I like to keep tire load to maximum 75% of rating. If I can't get make that goal, I get a higher rated tire... either higher ply rating or bigger. I inflate to rated pressure + 5 psi. I have mostly run trailer tires on my trailers but would not hesitate to run LT.
As general comment, trailer tires are rated at a certain speed and temperature (?? 65 MPH and ?? degrees F). Running hotter or faster de-rates the tires thus the need to have extra capacity.
Re: Race trailer tires, I HATE them! [Re: ahy] #2527638
07/26/18 10:42 PM
07/26/18 10:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I checked mine again tonight as I like to keep them at 90 pounds. All ready for another race weekend.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Race trailer tires, I HATE them! [Re: Twostick] #2527720
07/27/18 02:15 AM
07/27/18 02:15 AM
Cab_Burge Offline OP
8600 is a lot of weight on what I'm assuming is a 235/75/15 x 4. If it was a 1/2 ton pickup you would have to have 3500 lbs. in the box to weigh that and you'd be surprised to get out of the driveway.
Kevin [/quote]The tires are 225x75x15 ST E rated for 2830 lbs. per tire, the axle weights is what I posted so it has 11320 Lbs. load carrying abilty on all four tires and 8490 lbs. on three tires shock
the truck weighs a tad over 7600 Lbs with me in it with a half of tank of diesel and the trailer hooked up going down the road to the races with the old duster in it. My current S/P car weighs right at 1000 Lbs. less than the Duster did boogie
I am going to reweigh it again empty and then with the new race car in it so I have current weight on the trailer going down the road.
I dug through my tire receipts for the truck and trailer and the tires that blew out may have been over ten years old work tsk blush
I will buy the covers and use them from now on up
Hopefully this post will help someone else from repeating my mistake, I honestly thought that the tires on the passenger where less than three years old realcrazy blush
Thanks to all for your help and comments bow up
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2527795
07/27/18 11:17 AM
07/27/18 11:17 AM
MA
K
Kevin Kowalski Offline
K
MA
Kevin
Thanks to all for your help and comments bow up [/quote]
My 2 axle trailer with living quarters is close to 10k lbs. loaded. As Cab stated, my ST225/75 15, E rated tires have a total weight rating of 11,320 lbs. I just put 4 USA made Goodyear Endurance tires on a couple of weeks ago because I didn't trust the Chinese made tires that were on it any longer. The Endurance trailer tires are highly recommended by many people and I'm happy with them after just coming back from an 850 mile round trip.
Re: Race trailer tires, I HATE them! [Re: Cab_Burge] #2528130
07/27/18 11:50 PM
07/27/18 11:50 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
For an extreme case you may want to check out 19.5" conversions. It is fairly common for trucks with heavy campers to swap out 16" to 19.5". Much heavier load capacity than any 16". Just a thought.
" The last official act of any goverment, is to loot the treasury" George Washington
