Page 5 of 5 1 2 3 4 5
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2526423
07/24/18 02:37 PM
07/24/18 02:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a 260@ 50 solid( on a 106) in at 102 in my car and it idles happily at 1100 rpm like a Packard. Stock stroke 360
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2526472
07/24/18 04:23 PM
07/24/18 04:23 PM
Gravataí, RS, Brazil
360tripleblack77 Offline
I'm running with a 360 engine that made 464WHP using Super Victor Intake and Mighty Demon 750. So I've changed to Tunnel Ram and two Mighty Demons 750. I didn't run on dyno after that but the time on the track drop from 6.98 to 6.73.
You can see the setup at this video:
https://www.youtube.com/watch?v=ap8u2OfaBCw
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: 360tripleblack77] #2526475
07/24/18 04:28 PM
07/24/18 04:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The super Victor Intake sucks until you do major porting on one
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: 360tripleblack77] #2526620
07/24/18 09:51 PM
07/24/18 09:51 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That sounds great, what cam?
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: 360tripleblack77] #2526744
07/25/18 05:34 AM
07/25/18 05:34 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
WOW. Sounds great! Ya see...that idle. Looks like it was @ 1100? I could live with that for a driver. imagine seein' that thing pull up at a stop light. laugh the joy.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: pittsburghracer] #2526758
07/25/18 08:58 AM
07/25/18 08:58 AM
I agree John! On my SV I did a deep port match and a basic plenum rework. I did the same work on tunnel ram. Measuring Weiand Tunnel Ram I can see that it has a lot of little points where I could work, starting by port match and going through runner until the plenum...
Best 1/8 mile ET
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Skeptic] #2526761
07/25/18 09:12 AM
07/25/18 09:12 AM
It's a Solid Flat Tappet Custom Comp Cams 256/260@.050, 108 Lobe Center and .580/.600 lift in.
Best 1/8 mile ET
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: mopardude318] #2526765
07/25/18 09:19 AM
07/25/18 09:19 AM
You're right! Idle is 1100 RPM and believe me, that's amazing to ride on the street. Maybe in a 408" you can drop the idle around 1000 RPM easily...
Best 1/8 mile ET
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: 360tripleblack77] #2526770
07/25/18 10:02 AM
07/25/18 10:02 AM
PA.
"Little"John
"Little"John
PA.
I still have my super Victor Intake and did end up going 9.74 with it on my 408 but with two ported Indy intakes on the shelf not sure if I would ever try it again or not. Finally had a chance to watch your video last night and the car sounds great. Looks like a fun ride. Go out and have some fun
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2526779
07/25/18 10:40 AM
07/25/18 10:40 AM
Edmonton Alberta, Canada
R3DART Offline
R3DART  Offline
Deleted
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: pittsburghracer] #2527285
07/26/18 11:20 AM
07/26/18 11:20 AM
Thank you John! my goal for this year is run at 6.50s. Next race will be in september... Let's do it!!!
Best 1/8 mile ET
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2527507
07/26/18 06:14 PM
07/26/18 06:14 PM
ohio
72340rally Offline
72340rally  Offline
ohio
I have a stock stroke 340 in a 72 Duster that's all steel & glass that went 10.49 best in cool night air. It's got iron heads a roller cam and a holley 750.It goes thru the traps @ 7600, lots of FUN !
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2527530
07/26/18 07:19 PM
07/26/18 07:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Anyone know the conversion for 1/8 mile to 1/4 mile times?
How much would that be on the 1/4?
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2527541
07/26/18 07:33 PM
07/26/18 07:33 PM
delaware
dusterbuster71 Offline
delaware
you ran a 16.37 better put a slant 6 in it Lol
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: BigBlockMopar] #2527850
07/27/18 01:02 PM
07/27/18 01:02 PM
moparx Offline
moparx  Offline
i always use 1.57 x 1/8mi et to get 1/4 et. seems pretty close.
beer
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: moparx] #2528228
07/28/18 11:43 AM
07/28/18 11:43 AM
The Great White North
RAMM Offline
RAMM  Offline
500hp stock stroke 360
500 hp 360 with w2's
These are two of many examples I have built as I am not a huge fan of the 4" stroke stuff. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2528242
07/28/18 12:24 PM
07/28/18 12:24 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
true 500hp at crank is going to need good aftermarket heads
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: Streetwize] #2551526
09/18/18 02:55 PM
09/18/18 02:55 PM
Gilroy,CA.
Gilroy,CA.
Re: Show me a 500hp "default" stock stroke 340/360 recipie [Re: 360tripleblack77] #2551546
09/18/18 03:17 PM
09/18/18 03:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I am a big believer in having a high idle with a flat tappet cam.
Have a 1 wire alternator that charges from 1500 rpm on up. So at the track i keep it at 1500 so its always charging
1.41 best 60 foot
6.60 at 103.90 1/8
