Boostane/"Race Gas"/Torco Accelerator ??? #2525885
07/23/18 03:14 PM
07/23/18 03:14 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
My last engine ran fine on straight 93 E10 at 10.7 CR, but the CR's been upped to 11.5 now and I want to have a safety margin w/ my fuel choice. I don't have the benefit of 100 UL at the pump where I am, and expect to be blending some amount of actual race fuel w/ 93 E10 pump for street & strip use.
However, if I'm unable to get race fuel when needed, I figured I should keep a bottle of some type of "octane enhancer" in the car as a backup plan. Three brands that appear to be effective (to some extent) are Boostane, "Race Gas", and Torco Accelerator. I'm looking for anyone's experience and feedback on these products. I expect I'll need a ballpark octane level of 97-98 to work w/ my new engine combination, if that makes a difference.
Thanks - Brad
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525889
07/23/18 03:20 PM
07/23/18 03:20 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
This was a while back, but when I ran my 12:1 440 on the street, I used the NOS brand octane booster on occasion. They had a couple different versions...the one I used was the "race" version. It seemed to be way more effective than any of the other off the shelf brands at the parts store.
I normally ran either 100LL AvGas or a 50/50 mix of 93 and 110. When in a bind, I'd run 93 w/ that NOS race booster.
Not even sure if they sell it anymore as I haven't had a need for it in 15 years, lol.
I know this really doesn't help you. Just thought if they still made that additive, it might be worth you trying it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525897
07/23/18 03:35 PM
07/23/18 03:35 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Check out the VP Madditive stuff, no experience but it looks interesting
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525903
07/23/18 03:56 PM
07/23/18 03:56 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
FWIW, a couple individuals I know have been using Royal Purple Max-Boost.
72 Plymouth Roadrunner 11.08@123.25
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525906
07/23/18 04:04 PM
07/23/18 04:04 PM
Washington
madscientist Offline
Washington
Torco and Bootane are essentially the same, and are the only additives I know of that are formulated the way they are. They are more than octane boosters. They are a fuel conditioner as well.
I've looked into Race Gas a couple of years ago, but it wasn't made the same way as the other two so I just blew it off.
Somewhere in the web, there is a test of Boostane against pump gas, race gas, methanol/water injection IIRC. The additive did better than hold its own.
Torco was the company that started blending their additive the way that they do it. Of course, Evan Knoll was just a figure head. The real engineering was done by other people.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525908
07/23/18 04:06 PM
07/23/18 04:06 PM
jersey
Spaceman Spiff Offline
jersey
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2525945
07/23/18 04:48 PM
07/23/18 04:48 PM
Washington
Washington
BTW...there are at least two private label brands that are the same as Torco/Boostane. I just can't think of them now.
One last thought...I called Boostane awhile back and they didn't offer their product with lead. Ou can get Torco with lead and the private label stuff with lead.
My testing showed the lead made the same or more power with lead using less of the product.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: madscientist] #2525988
07/23/18 06:52 PM
07/23/18 06:52 PM
BradH Offline OP
BradH  Offline OP
"Octane booster", "race fuel concentrate", whatever you want to call it, I know there are a lot of choices out there, some that work and some that are worthless. I've used them in the past, but have tried to not rely on them. I don't like the MMT deposits (the orange "rust" on the plugs & chambers), but MMT is one of the additives that does improve the AKI (Anti-Knock Index).
I've Google'd the topic quite a bit over the years and it's tough to get consistent information, even about the same product as tested by different people. It's also (kind of?) interesting how some of the products might improve the AKI, but it doesn't translate into an improvement in power. Certain ones (e.g, Boostane, Torco) have shown small improvements in power as "pour in" tests, and additional improvements by raising the AKI and enabling a more aggressive tune.
IIRC, Torco Accelerator used to be available in a leaded and unleaded formula, but I can't find anything about the leaded version any longer. I think that's now called blending 110 leaded race fuel. grin
Like I'd first mentioned, I'd prefer to be able to mix a "real" race fuel w/ pump gas as the normal fuel fill. But I do need an alternative for when that doesn't work out.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526037
07/23/18 08:08 PM
07/23/18 08:08 PM
Washington
Washington
If you want leaded, you have to call Torco and ask for it. They don't show it on the web site but they have it. Also, at least one of the private label brands had a leaded version. They were back east IIRC. It may be less shipping if you live back east to use a private label brand.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526089
07/23/18 09:46 PM
07/23/18 09:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How much toluene is needed to make pump 92 equal to 112 octane.What is the cost difference to justify over just buying 112?
Does this apply to boosted applications? work
I have also read that W/M can make 92 pump cover up to 116 octane.
Don't like hoping it works,I have burnt pistons missing he tune.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526092
07/23/18 09:48 PM
07/23/18 09:48 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Ive used Torco before. Blended it to 98 octane supposedly. '03 Cobra running 22lbs of boost. Never had any issues with detonation. Pulled 615rwhp.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526095
07/23/18 09:51 PM
07/23/18 09:51 PM
hemi-itis Offline
hemi-itis  Offline
What was your effective CR with 22 lbs??
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: Belvedere2] #2526138
07/23/18 11:08 PM
07/23/18 11:08 PM
Washington
Washington
I'm ASSuming that was the unleaded Accelerator. Am I correct.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526147
07/23/18 11:24 PM
07/23/18 11:24 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
My brothers buddy has a product called Liquid Horsepower Octane Booster. His buddy who created it worked for Chevron Oil as chemist. He started his own company 25 years ago called Manhattan Oil. Very good product. Go to manhattanoil.com.
Then you can check out rbracing-rsr.com. Go to products click water injection. Then scroll way down the page. There will be a Toluene formula. You may want to read more stuff on RB Racing. There water injection pump is killer. Definitely read the water injection part while you are there.They do turbo kits for street Harleys Top Fuel Harleys fuel injection water injection. lots of good reads on there. Don't let it fool you because it's a Harley performance site. It's all applicable to the internal combustion engine. These guys are extremely hi-tech and know their stuff. Big time Bonneville guys. Like my buddy told me who has dealt with them. These guys know how to hold stuff wide open for a long time and make it live.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: hemi-itis] #2526206
07/24/18 01:18 AM
07/24/18 01:18 AM
jersey
jersey
I have no idea on the ratio, but I know it was a trick the grand national crowd used.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: BradH] #2526211
07/24/18 01:35 AM
07/24/18 01:35 AM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Torco today is NOT the same as the Evan Knoll Torco.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: mopacltd] #2526219
07/24/18 01:57 AM
07/24/18 01:57 AM
Washington
Washington
What's the difference? AFAIK all the formula is the same. Evan Knoll was not the guy who developed the products.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: madscientist] #2526301
07/24/18 11:30 AM
07/24/18 11:30 AM
Belvedere2 Offline
Belvedere2  Offline
Unleaded yes.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: hemi-itis] #2526302
07/24/18 11:32 AM
07/24/18 11:32 AM
Belvedere2 Offline
Belvedere2  Offline
That I don't know. I had the car tuned on a dyno. As they say I just drive em I don't know how they work. Lol.
Re: Boostane/"Race Gas"/Torco Accelerator ??? [Re: madscientist] #2526345
07/24/18 12:49 PM
07/24/18 12:49 PM
BradH Offline OP
BradH  Offline OP
Question for anyone who can provide input: What's harder on O2 sensors, MMT deposits build-up or lead from a 50/50 blend of pump 93 E10 fuel and 110 leaded race fuel?
