Electronic distriutor interchange
#2526084
07/23/18 09:43 PM
07/23/18 09:43 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
Looking to replace the stock dual point distributor in my car with an electronic unit. (really!) I have a few electronic distributors laying around, some nicer than others. Is there any difference between a big and small block version other than the length of the shaft? The housings and guts all look the same to me. Any reason I can't swap the shaft from my old grimy B motor distributor into a nice clean small block housing?
'71 Duster '72 Challenger '17 Ram 1500
Re: Electronic distriutor interchange
[Re: RMCHRGR]
#2526113
07/23/18 10:24 PM
07/23/18 10:24 PM
RapidRobert
yes the electronic B shaft will fit the SB electronic housing. As noted the rotation is opposite so just eyeball the fitment of the vac can arm into the locating hole in the top flat plate so your vac adv is operational which it sounds like you have already done & if good on that system then you're set. While you're at it I would set the shaft end play to .005" with flat no bevel shims above the plastic collar & speedway mtrs has a nice selection of em for $10
[Re: RMCHRGR]
#2526123
07/23/18 10:33 PM
07/23/18 10:33 PM
RMCHRGR
Spahn Ranch
Oh yeah, duh. Didn't think of that, thanks. I see it now, the slot for the pickup and vacuum advance is on the opposite side. They looked the same on the bench. Guess I can take it apart and clean it.
But about that Black Flag avatar... I saw them...
[Re: RMCHRGR]
#2526263
07/24/18 08:25 AM
07/24/18 08:25 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
If removing vacuum, housing between BB and SB can be used on any block. Pickup coil, rotor and vap are the same, Reluctor too, just need to be indexed propperly. Shafts between SB B and RB are diff lenght. There are non floatng pick up coil plates able to be installed to remove the vacuum pod. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F190808914361( these are some interesting tips to use your imagination )
[Re: JAMESDART]
#2526362
07/24/18 01:07 PM
07/24/18 01:07 PM
RapidRobert
No, if you put a comma at the beginning of a sentence, that is what the SB ones look like. A comma at the end of a word like the one after the (No) mirrors the shape of the BB ones.
[Re: RMCHRGR]
#2526749
07/25/18 06:16 AM
07/25/18 06:16 AM
NachoRT74
Valencia, España
Nothing about the shaft, but just the "advance plate"
