Page 2 of 7 1 2 3 4 5 6 7
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2585131
11/30/18 12:40 PM
11/30/18 12:40 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Nice score, and keep up the good work. Thanks for the needle scaller tip.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2585212
11/30/18 03:23 PM
11/30/18 03:23 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice job. That needle scaller did a very nice job. I used a Harbor Freight pneumatic scraper while wearing ear muffs.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: larry4406] #2585806
12/01/18 07:55 PM
12/01/18 07:55 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Wow, had not seen the car taken down this far!
'63 Dodge 330
11.19 @ 121 mph
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2610826
01/23/19 01:40 AM
01/23/19 01:40 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The stock wheel tub shape/profile drives me crazy so these are getting modified heavily.
This is the passenger side tub. A widening strip was welded in place.
The slope of the outside tub leaves a lot of tire space on the table. On a stock Charger, the tires look silly because they are set back so far away from the wheel lip. Everything inside the green tape line will be cut out. And when you look from the front/back you will see a yellow card that is displaying the new profile/slope of the outer tub.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2610831
01/23/19 01:44 AM
01/23/19 01:44 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
With the new outer tub.....which started out as a single piece of steel...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2610841
01/23/19 01:59 AM
01/23/19 01:59 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Side by side comparison:
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2610918
01/23/19 10:23 AM
01/23/19 10:23 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Very nice!!!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: MoparJunkie] #2638313
03/29/19 12:29 AM
03/29/19 12:29 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I wandered over to Matt's shop to take some pics of the car. In the last two months, the AMD quarter panels arrived are just hanging on the car in these pics. Matt also removed the original K member/front suspension and installed the Reilly Alterktion front suspension. Also, my 70 Barracuda photobombed this picture (it's in the background).
I parted a wrecked 1970 Challenger last year that was equipped with this aftermarket 9" rearend wit Baer discs and a 4.10 limited slip diff. Since I have it already, I'm going to use it. I ordered a Reilly Motorsports 4 link-you can see the bar in the trunk.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2767432
04/23/20 01:27 PM
04/23/20 01:27 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Well, a year later its making some progress...new AMD quarter panels, dutchman's panel tail light panel, rear crossmember, rear valance, one piece trunk floor, and trunk floor extensions.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2810988
08/20/20 09:05 AM
08/20/20 09:05 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The RMS 4 link bar has been welded in. The Ford 9" rearend will be narrowed to fit my wheels and tires.
Also, I changed direction on the transmission. I had a TR6060 laying around in my shop from when I parted out a late model Challenger SRT8 so I'm going to use it. So the tunnel had to be enlarged...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2811059
08/20/20 12:40 PM
08/20/20 12:40 PM
Spain
K
Kizzo Offline
Kizzo  Offline
K
Spain
Nice work, please keep posting photos of your progress. It's a really interesting project that you are doing there. When I retire and will live in my summer property in Spain I want start a similar project just to keep myself busy.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: Kizzo] #2813767
08/26/20 10:25 PM
08/26/20 10:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Smooth firewall coming....
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2814638
08/29/20 09:46 AM
08/29/20 09:46 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A few pictures of the start of the tunnel...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2819779
09/11/20 07:07 PM
09/11/20 07:07 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Firewall is roughed in...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2820421
09/13/20 09:40 PM
09/13/20 09:40 PM
Superfreak
Superfreak
Lots of work going on there. up
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: ] #2821178
09/15/20 05:02 PM
09/15/20 05:02 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks!
Windshield wiper motor notch is gone...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2825504
09/27/20 12:09 AM
09/27/20 12:09 AM
Superfreak
Superfreak
The wheel houses were done very nicely. See a lot of guys doing it but cutting the piece all to sh it and welding pieces here and there to make it work. up
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: ] #2826272
09/28/20 09:31 PM
09/28/20 09:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks!
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2826579
09/29/20 07:01 PM
09/29/20 07:01 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Firewall is in place...also the 6.4L BGE Hemi and the TR6060 were mated and installed for mockup of the transmission crossmember.
A front lower radiator support was built since I'm not a fan of some of the other aftermarket offerings. It's got a pocket on the passenger side to account for the vintage air conditioning condenser/hard lines.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2826581
09/29/20 07:03 PM
09/29/20 07:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
