Ritter racing block design flaw
#2525334
07/22/18 02:09 PM
07/22/18 02:09 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
As many of you may know we have been struggling with an internal water leak on this block since it was new.. causing premature hone damage.. that being said when it runs it runs strong. This is a naturally aspirated engine.. that lives in an extremely harsh environment and it's put to the test every pass.. we tore the engine down to clean install some epoxy in the block And hone.. upon disassembly we noticed the block was cracked at the three Center cam bearings.. the block is extremely thin there because of its design it is approximately approximately 7/16 of an inch wide from the bearing register to the oil drain Passage..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Ritter racing block design flaw
[Re: WHITEDART]
#2525339
07/22/18 02:20 PM
07/22/18 02:20 PM
WHITEDART
bean town ....Ca
I am no engineer however it appears. The way the cam tunnel is closed off from the top and open on the bottom there is a significant amount of movement that's taking place causing a crack in these thin areas.. the cracks were not visible to the eye until this go around.. however the motor would not hold cam bearings very well since day one.. which tells me they have always been there and probably open up with heat causing the bearings to lose their press.. this application is a 55 mm cam
[Re: racerx]
#2525344
07/22/18 02:27 PM
07/22/18 02:27 PM
WHITEDART
bean town ....Ca
The motor would not hold cam bearings until I made these retainers.. this image will kind of give you an idea of what the design of the cam and Valley area look like
[Re: racerx]
#2525346
07/22/18 02:29 PM
07/22/18 02:29 PM
WHITEDART
bean town ....Ca
WD...ever thought bout trying one of the newer casting blocks? only if someone gave me one for free and all the machine work was done to my specs and it wouldn't cost me a dime .. FYI this is a second generation Ritter block.. this is neither a casting or Machining flaw it is structural
[Re: WHITEDART]
#2525352
07/22/18 02:36 PM
07/22/18 02:36 PM
Posts: 4,066 Mo.
racerx
Mo.
WD...ever thought bout trying one of the newer casting blocks? only if someone gave me one for free and all the machine work was done to my specs and it wouldn't cost me a dime .. FYI this is a second generation Ritter block.. this is neither a casting or Machining flaw it is structural curios to know , how many pass's on this block?
[Re: WHITEDART]
#2525366
07/22/18 02:56 PM
07/22/18 02:56 PM
Posts: 4,066 Mo.
racerx
Mo.
gotcha…. I remember there were a lot of issues with that block when it was first cast. so what are the plans now?
[Re: WHITEDART]
#2525383
07/22/18 03:51 PM
07/22/18 03:51 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
VERY disappointing, just more junk made for mopars. very sorry for you WD
[Re: CSK]
#2525395
07/22/18 04:14 PM
07/22/18 04:14 PM
Posts: 4,457 Washington
madscientist
Washington
VERY disappointing, just more junk made for mopars. very sorry for you WD Junk? Really? I've seen almost every brand of block crack there.
[Re: Skeptic]
#2525400
07/22/18 04:26 PM
07/22/18 04:26 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Have you show this to Ritter? That would be an exercise in futility
[Re: WHITEDART]
#2525418
07/22/18 04:47 PM
07/22/18 04:47 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I hate reading this kinda stuff!!Have they come out with a new and improved block? Who else makes an aftermarket block for the W8??
[Re: Al_Alguire]
#2525426
07/22/18 05:04 PM
07/22/18 05:04 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Have you show this to Ritter? That would be an exercise in futility If you are expecting a refund or exchange, sure. They can't fix-or be expected to fix, problems they don't know about. Sending an e-mail with a few pictures isn't really much "exercise".
[Re: hemi-itis]
#2525438
07/22/18 05:33 PM
07/22/18 05:33 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I hate reading this kinda stuff!!Have they come out with a new and improved block? Who else makes an aftermarket block for the W8?? You can get an aluminum A8 block in a week if you are willing to part with $7000.00 Then buy the needed timing set for another 1000.... but you can get it.
[Re: WHITEDART]
#2525462
07/22/18 06:14 PM
07/22/18 06:14 PM
hemi-itis
Are the lifter bushings tall due to shallow lifter boss or for el notcho lifters?
