Dexcool and Mopars #252477
03/13/09 11:46 AM
03/13/09 11:46 AM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Is there any problems using Dexcool in our old Mopars? Any advantages or disadvantages? And how thoroughly does the Prestone have to be flushed before switching coolants?
Re: Dexcool and Mopars [Re: Kudakidd] #252478
03/13/09 12:09 PM
03/13/09 12:09 PM
moparmandc Offline
moparmandc  Offline
not sure bout using them in older cars don't see a problem. i think iam going to switch to the chrysler hoat (pink) antifreeze in my 79 truck. do not mix pink and green and do not use dexcool use the chrysler hoat coolant it is much better and is not the same as dexcool. i work in a gm and chrysler dealer and have seen way more cooling system problems with dexcool that the hoat. with corrosion and it gets kind of waxy in areas that don't have a high volume of flow. pretty much dexcool is junk. have not seen those problems with chrysler 5 year antifreeze.
Re: Dexcool and Mopars [Re: Kudakidd] #252479
03/13/09 12:41 PM
03/13/09 12:41 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Don't use dexcool unless it was really cheap; I would use Zerex G-05, that stuff is awesome. its oem in alot of cars and i've had it in my s10 for 4 years after I got fed up with the dexcool sludge despite cap changes and the works.
EDIT: zerex g-05 is a hoat tech coolant, just in case there was any confusion. we're recommending the same thing
Re: Dexcool and Mopars [Re: jerseybud] #252480
03/13/09 01:45 PM
03/13/09 01:45 PM
Kudakidd Offline OP
Kudakidd  Offline OP
What's really odd is that the Dexcool was put in my wife's Jeep by the dealership.
Re: Dexcool and Mopars [Re: Kudakidd] #252481
03/13/09 02:09 PM
03/13/09 02:09 PM
moparmandc Offline
moparmandc  Offline
are you sure it is dexcool or the chrysler antifreeze cause the color looks the same. (chrysler engineers must have seen the same things i am talking about) i took an engine class through chrysler bout 2 years ago and they stressed not to use dexcool cause they are not the same. gm has been using it since 96 and i have seen a lot of problems. chrysler has used hoat since about 00 or 01 and i have not seen any issues that i would atribute to antifreeze. take apart a gm with the same amount of time and miles and put a chrysler beside it and you will see the difference. we still put dexcool in gm and hoat in mopar but dexcool is job security for me at the dealer.
Re: Dexcool and Mopars [Re: moparmandc] #252482
03/13/09 02:15 PM
03/13/09 02:15 PM
moparmandc Offline
moparmandc  Offline
i was looking at a jug of dexcool at the shop and it said it meets gm and ford spec's but nothing about chrysler. do what you wish but stay away from dex.
Re: Dexcool and Mopars [Re: moparmandc] #252483
03/13/09 02:19 PM
03/13/09 02:19 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Moparman, I will check into this more carefully. Thx.
Re: Dexcool and Mopars [Re: Kudakidd] #252484
03/13/09 05:07 PM
03/13/09 05:07 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Dexcool is crap.Dont use it period.Look at some GMs sometime.They look like mudholes.Either use green or we use the new Global stuff that mixes with anything.Two years in the 65 with aluminum heads and still good.I also doubt that a Mopar dealer used Dexcool.Probally the new Mopar stuff that is overpriced.Rocky
Chrysler Firepower
Re: Dexcool and Mopars [Re: therocks] #252485
03/13/09 07:20 PM
03/13/09 07:20 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
which is same as g-5
Re: Dexcool and Mopars [Re: 05dakota] #252486
03/13/09 08:57 PM
03/13/09 08:57 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
We have had water pump failures on our Libertys at work. When you pull the pump there is a ton of pitting and it is usually eating its way through the gasket surface. Our vehicles do get used ALOT though, they pretty much are running 24/7.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Dexcool and Mopars [Re: phantomx] #252487
03/13/09 09:08 PM
03/13/09 09:08 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
IMO the MOPAR 5 year coolant seems to be corrosive I see a crust residue on components like radator caps and overflow bottles. Stick with green coolant.
Re: Dexcool and Mopars [Re: SALEM1912] #252488
03/13/09 09:46 PM
03/13/09 09:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I work in an independant repair shop and we see tons of cooling system problems from the newer style coolants, especially dex-cool. Green was fine in all the old cars and it is cheaper so I don't see any reason to use anything else. When you buy antifreeze the trick is to buy a name brand that has the proper aditives in it and use only DISTILLED water, that would be a fool proof plan for coolant.
Re: Dexcool and Mopars [Re: HotRodDave] #252489
03/13/09 09:58 PM
03/13/09 09:58 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
guess I am lucky since 96 we have had a 96 1500 pu a 96 boneville 4 different vetts and a saturn all with dex cool and have never had a cooling problem out of 1 of them right now the wife is driving a 05 vette with 60k on it and the dex cool still looks new.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Dexcool and Mopars [Re: HotRodDave] #252490
03/13/09 10:32 PM
03/13/09 10:32 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I have been buying the premixed coolant lately, no hassle and no guesswork.
Travis..
Re: Dexcool and Mopars [Re: therocks] #252491
03/13/09 10:47 PM
03/13/09 10:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
We dont even keep the dex cool on the inventory.
Re: Dexcool and Mopars [Re: Kudakidd] #252492
03/14/09 01:03 AM
03/14/09 01:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've been running for several years nothing but Zerex G-05, 60% coolant/ 40% water, with a 12 oz additive of Redline waterwetter,.......very effective in a hot running car,.....esp wingcars, as they have reduced, and relocated grille openings,........the only problem I have now, is the car runs too cool
Re: Dexcool and Mopars [Re: HotRodDave] #252493
03/14/09 09:55 AM
03/14/09 09:55 AM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
The difference is in the additive package. All coolants (besides RV coolant) is ethylene-glycol based. The old "green" coolant we know and love is phosphate and silicate based. This coolant requires frequent service and does have corrosion issues with newer dissimilar metals (i.e. aluminum, iron, magnesium, etc.). So, the OEM's tried to reformulate their coolants. OAT is Organic Acid Technology coolant, and is what GM uses. HOAT is Hybrid OAT coolant, which is what Ford, Chrysler, and Honda use. The differences get very technical, but suffice to say NOBODY wants to use Dexcool in their car but GM. Honda threw a fit when GM insisted that Dexcool was to be used in the 3.5's in the Saturn Vues. Here are a couple of links to articles by Motor Magazine. They're very informative and will answer a lot of questions.
http://www.motor.com/article.asp?article_ID=816
and also, a more recent one...
http://www.motor.com/article.asp?article_ID=938
Mark
Re: Dexcool and Mopars [Re: Kudakidd] #252494
03/14/09 09:57 AM
03/14/09 09:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That stuff SUCKS , DON'T DO IT .
I just worked on a car that had dexcool that was supposed to have it , you should have seen the SLUDGE that was in the radiator.
Re: Dexcool and Mopars [Re: 734x4PW] #252495
03/14/09 10:08 AM
03/14/09 10:08 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Mark, very interesting articles. Looks like I'm going to have to go back to service and insist they switch back to ethl glycol. The engine is a straight 6 in my wife's 96 Jeep, and I don't know why they made the change in the first place (while they installed a new radiator).
Re: Dexcool and Mopars [Re: Kudakidd] #252496
03/14/09 07:28 PM
03/14/09 07:28 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
dexcool has alot of problems, we take it out of as many customers cars as possible, GM is being suied over it, type Dexcool on google and check it out? i recommend that any body that has it in the cars or truck get it out before 75,000 and your problems could start.
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
