Re: 15" tires with a v speed rating
[Re: geo.]
#2523167
07/17/18 05:07 PM
07/17/18 05:07 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Geo --I've run Hoosier DOT A6 radial tires 275-45-16 f/r on my 16x10 rims for may past years.. but they are not easy to drive on "streets".. better on highways... they will find and follow the grooves in the roadways, and because they are so sticky (40 TW) they do pickup lots of debris. BUT.. they stick like glue when autocrossing or on road race tracks (HSAX/HPDE).
The Hoosier DOT R6 simply takes longer to heat up.. better for HPDE events and longer life.
And now, Hoosier has made further improved versions.. A7 and R7.
I've also run Hoosier "Street TD" DOT bias ply tires 245-60-15 f/r on my factory Mopar 15x7 rally rims... again, a bit squirmish on streets, better on highways... and they stick great for competition events.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: geo.]
#2532127
08/06/18 01:22 AM
08/06/18 01:22 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Anyone admit to running 15" hoosier DOT marked tires on the street? I'm thinking of the autocross, and road race tires, but I think there are oval-track DOTs also. Many racing slicks don't hold air for long periods, do these? I know we don't plan to drive our classics in the rain, but stuff happens! So how are the hoosiers? Any greater tendency to pick up road debris that can cause punctures? In reverse order. All R-comps will pick up extra everything from the road. Pebbles to glass,you name it, it will stick on especially once they get a little heat in 'em. I ran Hoosier Street TDs for autocrossing. 245/45-15 bias ply on Circle Racing spun aluminum rims. Very fun and forgiving of overdriving. That also makes them difficult to drive to their max potential as its hard to detect he best slip angle. Dave Mapes and I ran them back to back against a set of Toyo RA1s in the same size and rim. We both ran better times on the Toyos. Only had the Hoosiers on public roads once, for a couple miles or so, may be less. The sidewall is thin and the tires are very light. Unless the paving you'll be on is in top condition, these tires are really not appropriate for public roads. I've driven other DOT R comp tires to and from events - ones that are heavier constructed. Definately some do have more of a tendency to follow road surface than a street tire - especially if there is some toe out in the alignment. My Yok 008s used to drive me nuts on the NJTPK, but in retrospect part of that was the alignment. Toyos RA1s are decent in the rain. The 888 which I switched to recently isn't supposed to be quite as good in that respect. But the 888 is available in 235/50 and requires less negative camber.
Some of the pebbles stuck to the left tire visible in this photo of the car at the starting line. RA1You can see the send and pebbles sticking to the very worn and old RA-1 in this close up. Taken at my garage - not at an event so the tires were not hot.R888 at NJMP track dayRA1s, Autocross in rain
[Re: SANDYinNS Canada]
#2571970
10/31/18 06:25 AM
10/31/18 06:25 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Okay, i dont get in here much these days, i play in the general section as this one is just too goddamn depressing for me. But this is an area where i have spent some time... a LOT ov time...
(enough time to know to just bite the bullet, toast the passing ov the retro look, and go 18", but i still know 15" stuff)
Firstly, Mitch is always on about the 16" options, but i dont see it as a viable one, not anymore. There was a time when 16" worked, it was a short window ov about 2 1/2 months somewhere in the late 80's, but 17" became the game pretty much instantly. There IS one really good excuse to go 16" though, and thats if you still wanna fool people that its stock. Its not hard to concoct a 16" 'stock' rim, and honestly, VERY few guys will notice its not 15". I've seen this time and time again. Hell, i've seen staggered fittings (16" front, 15" rear), where no one noticed. The only way they'll notice is because even a 255/50-16 looks really short on a big car. Very expensive route, but if you got the coin and REALLY need that stock look...
Tom, i know you and i have been over this a hundred times, but its been so long i forget. Have you actually run the Maxxis tires? I have not heard a single good thing about them from a user yet, except from SUV people who dont drive their rigs. They're supposedly (despite ratings) hard and noisy. Oh, and heavy.
On actual 15". Check out Kumho. Ov all the places after years and years ov search, it was my local tire guy that found these. Kumho makes a V-rated 295/50-15 (and maybe other sizes too?). Its an Ecsta, and it looked a lot better than the Maxxis for performance use. Price was reasonable too. Thats as good as its going to get on a 'public' tire. If you try, you can fit a 295 all the way around on an E-body, and certainly many B-bodies. Even if not, it might be worth some minor mods, as it will look MEAN. Like, vintage stock-car mean. This is where i was going with my last Challenger... at least until i could afford the Forgelines and 335's...
And then i found (sorry, forget who linked it to me) there is a whole WORLD ov performance 15" racing tires. There is one Tire store/chain/dealer (again, forget), out ov California i think, that has a solid handful ov options for 15" racing tires. Yeah, you'll have to drive illegally, technically, but whats worth more, breaking some stupid law... one that likely no cop is going to call you on, or saving your car, or life? EASY decision. Also, most ov these options will be bias ply. Not as good an option, but still... guys race expensive cars on these things. How bad could it be? I remember Goodyear had a few racing options, Hoosier had a few good ones, there were more common brands and also some i've never heard ov.
I want to clarify that the above options were all treaded tires, so to the casual observer or cop, they're a legal tire.
I've also now (finally) seen the Mickey Thompson 15" tires on an autocross car... a particularly nasty looking road race 67 Camaro. He said so far, in and around town they felt good, but had not yet raced on them. He has since, but i've not run into him to ask.
So... there are quite a few more options in a HP 15" tire than most people think exist. Enough to let you keep those widened rallyes or Super Coupe rims on the ol' girl. Dig... and ye shall find.
#2580764
11/20/18 08:31 PM
11/20/18 08:31 PM
Posts: 3,934 Nova Scotia Canada B2Y 1E4
SANDYinNS Canada
I hope so it is a badly needed item!
Sandy in Nova Scotia formerly drdodge340 68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute -76 feather duster-76 duster-77 street van - 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
#2581038
11/21/18 01:40 PM
11/21/18 01:40 PM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
Here is an older thread where we beat up the 15" tire subject way back in 2013. Some things have changed a bit, but much less than it did from 2008 to 2013 when it was previously beat up. Since the forum won't allow searches older than 10 years, the early 2008 threads have disappeared. https://board.moparts.org/ubbthreads/ubbt...tml#Post1519474There are high speed and high traction 15" options out there. However, either prepare to pay a lot for them, or run them as an outlaw race item on a street car. If someone is preparing to make a V rated G60-15 that appears to be period correct in Polyglas or Wide Oval livery, your gonna pay for them. Upside is their life cycle and wear resistance (bias plys won't tolerate the alignment angles a radial will so their wear will be accelerated) will probably be so short that you'll still replace them regularly despite the low mileage of a collector car. No chance to dry rot em. These guys offer a wide variety of vintage, historic, race, street, custom treaded slicks and TA style wheels. This is their price list sheet, so click through each tire name to see different offerings. some have pictures, some just size and prices. Want VR rated 15" tires, $500+ and most sizes are limited to 205-255 section widths. https://rogerkrausracing.com/index.php/race-tire-pricing/These guys used to be know as McCreary. As a race tire manufacturer, they have a whole lot of selection in 15" to includes slicks, treaded, and d.o.t. carcass designs. Most are bis play, but there are some radials mixed in there too. 13"-15" sizes are their specialty. https://americanraceronline.com/Of course Hoosier is well known and prolific with their race tires. Bias and radial, slicks to wets, d.o.t. and more. They have some discontinued 27x8x15, four groove asphalt slicks in there for $50 each. Want an inexpensive G60 bias ply race tire with tread that looks street legal and grips like mad, how about the IMCA spec tires for under $125 each. Hoosier has em. Main Hoosier site: http://www.hoosiertire.com/IMCA G60s: http://hoosiertirewest.com/g60-15-imca/A lesser known provider outside of outlaw bullrings, these guys have been making racing tires and retread racers for decades. Don't shake your head at the retread part. I've abused their retread designs in racing environments for years without a separation. How about a tire with 3* of camber built into the tread face? These guys make em. They also make vintage pie crust slicks for the drag racing guys. https://www.towelcityracingtires.com/
