When someone oils down the track #2522553
07/16/18 02:01 PM
07/16/18 02:01 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Yesterday at local race track
Non-Mopar
At about the 1250 mark, his filter gasket decided to leave its home (Wix)
Put 2 1/2 quarts on the track, he went for a wild ride but, kept it pointed mostly straight , fast car ..
I have known him for most of my life, told him .. don't run it again
"why?) --I said, well I bet you nicked a bearing or two or all
Bet it lost oil for moment and at 6000 + rpms, it hurt it
said still has Oil pressure ?
so worried about points, goes up
and dumps the crank on the track , and was really upset about all his bad luck ..
2nd ride was wild again but, got it gathered up
That wasn't bad luck , that was being stubborn
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: When someone oils down the track [Re: bigdad] #2522561
07/16/18 02:16 PM
07/16/18 02:16 PM
Washington
madscientist Offline
Washington
Non-Mopar
That wasn't stubborn. That was stupid. He isn't paying his mortgage with his winnings. If he is he's a fool. It's his hobby. Not his life. And even then, it's not worth the carnage to do what he did for a trophy that has little value
That was just stupid. No excuse. Stupid.
Re: When someone oils down the track [Re: bigdad] #2522562
07/16/18 02:16 PM
07/16/18 02:16 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Or stupid!!!!!!!!!!!!!! LOL.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: When someone oils down the track [Re: madscientist] #2522563
07/16/18 02:17 PM
07/16/18 02:17 PM
PA.
"Little"John
"Little"John
PA.
Non-Mopar
You beat me.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: When someone oils down the track [Re: bigdad] #2522565
07/16/18 02:20 PM
07/16/18 02:20 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
he has I think at last count 8 drag cars
he had two at the track being raced by others yesterday ( non family)
He is just a dedicated racer, has won several track championships
good guy but, a bit too determined to get back to Memphis
I'm glad he didn't put it on the cage , he did some driving
Re: When someone oils down the track [Re: pittsburghracer] #2522568
07/16/18 02:21 PM
07/16/18 02:21 PM
Washington
Washington
Non-Mopar
You beat me.
HA! It so rare I get the drop on anyone I'm giving myself a morning candy bar!!! I get the giggles when I cut an .080 light!!
Re: When someone oils down the track [Re: bigdad] #2522589
07/16/18 02:47 PM
07/16/18 02:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not to mention making a mess for the track to clean up, twice, and endangering the guy in the other lane.
Re: When someone oils down the track [Re: bigdad] #2522596
07/16/18 03:00 PM
07/16/18 03:00 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
1st time , ok ..but that 2nd one was not needed
Re: When someone oils down the track [Re: bigdad] #2522604
07/16/18 03:23 PM
07/16/18 03:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
A brand new 'Vette went off the end of the track a couple of years ago at Tulsa Raceway Park when we were there. I was the next one down in his lane and saw backup lights!! Fortunately he was stuck in the gravel.
Stock 'Vette, no reason to go off as they have a long shutdown area.
He has a belly pan and suspension FULL of gravel and what does he do? Promptly pulls back around to the starting line and dumps that all over the track during his burnout!! mad
'63 Dodge 330
11.19 @ 121 mph
Re: When someone oils down the track [Re: GY3] #2522823
07/16/18 10:15 PM
07/16/18 10:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
some guys just don't get it shruggy
Re: When someone oils down the track [Re: bigdad] #2522855
07/16/18 10:55 PM
07/16/18 10:55 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Made my last time run at a Divisional in Tuscon, and heard a rattle on the top end. Told my buddies I was done, that I thought it hurt a piston. It was Saturday night, so we had a BBQ and some beers, and I must've fired the car 10 times so everyone could listen, and they all came to the same conclusion.
"It's fine! You're being paranoid! Pull up there for first round in the morning, and if it sounds funny down track, then lift, but at least give yourself a chance!"
They convinced me, so the next morning I rolled into the burnout box, grabbed the line lock, took it to 6K in low, then shifted to second and rolled out of the box. Right before the tires bit, the old 440 locked up and tossed all it's guts on the pavement!
Couple of pistons and a freshen, it would still be racing! Nothing was saved in the shortblock, destroyed a nice Milodon pan also!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: When someone oils down the track [Re: bigdad] #2522860
07/16/18 11:02 PM
07/16/18 11:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
if I was racing the Mirada.... the mill owed me nothing, I’d a filtered it, filled it and sent it!
Duster mill... unobtanium 9.20 deck. Precaution level much higher!
Re: When someone oils down the track [Re: bigdad] #2522874
07/16/18 11:24 PM
07/16/18 11:24 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Few years back on a Saturday night at Monster Mopar i was racing in no box 4th round. Norwalk. Some here probably remember this.
Was about three car lengths behind the guy i was chasing down, he broke out ultra bad( still cant figure that out) just as i crossed the finish line on a 10.01 pass, i went immediately toward the wall in the left lane.
I did an excellent job( in hindsight) saving the car from hitting the wall. Got it back to the middle, handled a couple major wiggles, and got it slowed down. Lots of smoke in the rearview mirror, and oops, zero oil pressure.
Wix oil filter let go.
Back in the pits i am white as a sheet sitting on a trailer while an army of friends jack up the car start brake cleaning under it, all over was oil , and Chuck Millen from Best Machine( who built the motor) offers up fresh oil and a filter. Must have been 50 guys around by this time, all helping in one fashion or another. Tires off, cleaning brakes, you name it, oil had gotten on it.
At this point i had zero intention of continuing on in eliminations while the track was getting cleaned up from my mess before the next round. Frankly a little shellshocked and nervous.
Somebody said, forget who it was now.... “ get back in that car now or you never will”
I ultimately got back in it, drove around the pits trying to find something wrong so i could avoid going back to the staging lanes.
I went back, zero issues ever again with that motor, that night, or at all until couple years later it was due for a freshen up due to amount of laps on it.
So, results can vary.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: When someone oils down the track [Re: J_BODY] #2522879
07/16/18 11:29 PM
07/16/18 11:29 PM
PA.
"Little"John
"Little"John
PA.
30 years or so as I was going thru the traps I glanced and saw my oil pressure drop. It was an old fashioned.030 over stock crank, stock rod, TRW pistons build that ran highs 9’s in the 1/4 mile. I loaded up and took it home that Sunday. I pulled the oil pan on my open car trailer at home to take a peek. As I started with number one main I pulled the cap and the bearing looked great and left the cap off. Number two was fair and when I pulled the thrust cap I thought I saw something move. Well I did as the crank was busted in half. I pulled the engine on Monday and tore into it changing the crank and bearings. With two friends taking care of the rods I lowered a fresh crank in, finished it up, and raced that Friday. Man I wish I could work like that now. This was evening work as I worked 8-4 in the steel mill.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: When someone oils down the track [Re: bigdad] #2522884
07/16/18 11:36 PM
07/16/18 11:36 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Big dad,
I realize this is minor point but I gotta ask...does this guy preach against over tightening oil filters and or is there a chance he simply put it on loose?
(Applying the 5 whys to this scenario)
Re: When someone oils down the track [Re: bigdad] #2522970
07/17/18 09:46 AM
07/17/18 09:46 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
No, he has multiple race cars and makes many laps , not sure why the gasket blew out, was not a fresh oil change so he told me
Re: When someone oils down the track [Re: pittsburghracer] #2522999
07/17/18 11:01 AM
07/17/18 11:01 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had this happen to a 340, i had made a pass and when I got my helmet off at the ET shack I though the car in front of me was knocking. It was then I noticed my oil pressure gauge bouncing. The car sounded like someone was beating on a frying pan with a spoon. I said this to my friends "oh well it was due to be freshened up anyways as long as its not the crank it will be OK". Took it apart that night and the only thing broken.....the crank! If I had another crank we could have made it back out for the midnight drags.
68 Barracuda Formula S 340
Re: When someone oils down the track [Re: bigdad] #2523003
07/17/18 11:13 AM
07/17/18 11:13 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
No diaper?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: When someone oils down the track [Re: bigdad] #2523008
07/17/18 11:18 AM
07/17/18 11:18 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
No
Re: When someone oils down the track [Re: bigdad] #2523010
07/17/18 11:22 AM
07/17/18 11:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Give Russ a call. Don’t be “that” guy smile
