Re: 1978 TF 727 speedo gear housing oil seal availability
[Re: TommmyBoy]
#2522501
07/16/18 11:08 AM
07/16/18 11:08 AM
Posts: 13,813 md
mopars4ever
md
try 4883434aa. you can find the kits on ebay. dealer part may be discontinued. also you may find the o-ring for the cable end at any parts store. i think the part number for the small o-ring is 1934822
Time just gets away from us I`m here until I`m not
[Re: TommmyBoy]
#2522503
07/16/18 11:14 AM
07/16/18 11:14 AM
Posts: 13,813 md
mopars4ever
md
BTW, you can change the plastic to the older style metal housing. you can use the older style gear that way which the gears are more available. many times the plastic housing gets broke trying to get them out and that may be why there is sealer on it. you would also have to change the speedo cable to the older style.
[Re: TommmyBoy]
#2522631
07/16/18 03:07 PM
07/16/18 03:07 PM
Posts: 13,813 md
mopars4ever
md
Of the smaller two seals in the kit I think the green seal is the one that fits the plastic adapter. It has been a while since I messed with it since I have changed my car over to the old style but if you have the old seal out you could compare the number to the one in the pic. I looked in my 77 book and the seals are older part numbers so you should be good to go.
[Re: TommmyBoy]
#2522794
07/16/18 08:02 PM
07/16/18 08:02 PM
Posts: 13,813 md
mopars4ever
md
40-45 minute drive to a trans shop for me.
