Gas tank question #2521468
07/13/18 02:27 PM
07/13/18 02:27 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
The drain plug in the bottom of the gas tank on my 55 Savoy is leaking and the gasket is all busted up. What material should I use to make a new one.
Re: Gas tank question [Re: CARMAN] #2521627
07/13/18 09:39 PM
07/13/18 09:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
copper or aluminum sealing washer
Don't be the exception.
Re: Gas tank question [Re: Supercuda] #2521799
07/14/18 01:36 PM
07/14/18 01:36 PM
moparx Offline
moparx  Offline
is it a pipe thread or regular thread ?
beer
Re: Gas tank question [Re: CARMAN] #2521800
07/14/18 01:37 PM
07/14/18 01:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pipe thread wouldn't use a gasket.
Re: Gas tank question [Re: Supercuda] #2521802
07/14/18 01:42 PM
07/14/18 01:42 PM
moparx Offline
moparx  Offline
that's what had me stumped. the tanks i've seen that had a drain usually had a bung that was pipe thread. if it is the common 1/2x20 thread, a gasketed replacement oil pan drain plug would be an easy fix. i have those with a copper gasket, as well as several that have an o-ring washer deal.
beer
Re: Gas tank question [Re: CARMAN] #2521811
07/14/18 02:12 PM
07/14/18 02:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Problem is compatibility. Some rubber falls apart in the presence of gasoline. I have no idea what those oil pan drain plug gaskets use.
Re: Gas tank question [Re: Supercuda] #2521837
07/14/18 03:03 PM
07/14/18 03:03 PM
moparx Offline
moparx  Offline
your copper/aluminum gasket ring would be the best fix, and relatively easy to procure.
beer
Re: Gas tank question [Re: CARMAN] #2521881
07/14/18 05:05 PM
07/14/18 05:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I used a rubber O ring on my '56, don't remember the size but the slight recess in the tank skin made the O ring compress without oozing out the side of the plug.
Re: Gas tank question [Re: John_Kunkel] #2521899
07/14/18 06:09 PM
07/14/18 06:09 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Sorry been out at an estate sale picked up a few items. I found some copper crush washers in the Mcmaster carr book at work yesterday. Just gotta measure the plug and get some that fit. Picked up some hub caps for an old dodge and a old sun timing light that still works. It's a 1953 model and is 6/12 volt.
Re: Gas tank question [Re: CARMAN] #2522055
07/15/18 10:26 AM
07/15/18 10:26 AM
moparx Offline
moparx  Offline
let us know what thread size that turns out to be. i'm curious. i have a plymouth cap similar to your last pic, only in worse condition, hanging in the garage ! the timing light is a nice score ! up
beer
Re: Gas tank question [Re: CARMAN] #2522265
07/15/18 08:29 PM
07/15/18 08:29 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
OK, I have a '56 Plymouth (wagon) that I am changing to fuel injection, the old original tank has not had fuel in it for many years. I took the plug out today to see what kind of gasket was used. I used a 1/2 drive extension for the double hex plug. NO gasket, I am sure there is supposed to be one, it just had disintegrated. The OD of the threads is 7/8 inches. I think any nylon or copper gasket would work.
Re: Gas tank question [Re: Old Ray] #2522325
07/15/18 10:48 PM
07/15/18 10:48 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
I should have the tank back this week I took it to have it cleaned up and checked out for any other leaks. That's my plan for the old Plymouth hub cap is to hang it in the garage.
