Re: EB 340 Torker II Single Plane Intake Any Good?
[Re: ScottSmith_Harms]
#252079
03/12/09 09:26 PM
03/12/09 09:26 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
had a torker 2 and it ran the same ET as a holley strip dominator..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#252083
03/13/09 09:34 PM
03/13/09 09:34 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
One just fell in my lap, are these a good intake for a street/strip car? Where do the fall in line as compared to the better similar application SB intakes available?
The 340 Torker is an abortion in the enth degree. The Torker II is a different animal and works much better. I prefer the results of the RPM, Airgap or even teh LD340.
[Re: MoparJim]
#252085
03/13/09 10:03 PM
03/13/09 10:03 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I cant say I had a 68 cuda with a 360 and a original torker that car ran real well.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: MoparforLife]
#252087
03/14/09 12:34 PM
03/14/09 12:34 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I was NOT happy with the one I ran for a short time. And I had MANY intakes to compare it to
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#252088
03/15/09 12:59 PM
03/15/09 12:59 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I really don't have anything to compare it to as I had to use one as it was the only performance intake that would fit using the stock AC..... It was either this single plane or a regular performer intake and that would have strangled my combo for sure......... It seems to have quite a bit of plenum area and provides plenty of upper rpm power. It is a bit soggy down low but not too bad. I run a 390 stroker in a 4140LB 83 Cordoba with me in it and my best time was 13.2@105mph... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: tpabayflyer]
#252089
03/15/09 01:27 PM
03/15/09 01:27 PM
Triple Threat
Renton Washington
The majority of your street/strip oriented crowd will say the Air gap intake is your best choice, good low end from its dual plane design with still enough plenum and runner volume to run well up top.
Torker 2 is a single plane intake, so expect a little less low end, but maybe a bit more up high depending on if the engine combo can use the bigger intake.
Depending on what its going on, it might not be the best intake available, but If one fell into my lap, I would probably use it.
