Why everyone needs a turbo
#2519606
07/09/18 05:09 PM
07/09/18 05:09 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
Re: Why everyone needs a turbo
[Re: 1980volare]
#2519614
07/09/18 05:22 PM
07/09/18 05:22 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Nice, blew the tires off, pedaled it, and still got him!
[Re: 1980volare]
#2519929
07/10/18 11:33 AM
07/10/18 11:33 AM
Posts: 4,206 New York
polyspheric
New York
50 hp worth of nitrous helps spool quite a bit.
Boffin Emeritus
[Re: 1980volare]
#2520064
07/10/18 04:40 PM
07/10/18 04:40 PM
Porter67
Nice, give em hell. I find it a bit amusing at the lack of replies since you openly street race, (makes you a bad guy) and drive a unpopular mopar body style and alot of time just got grief over some of your posts here for it but you could hand most racers here there ass on the street or track. My street racer will only pull mid 9-s so I couldnt touch your ride and a turbo seems so much smoother then spray and although a bit of a ego hit knowing this I dont know anyone whos not silently thinking "This guy is doing good". Since you street race and the grief you have gotten in the past, id not expect you to post all the details of your build. I think the mods should remove the "Lost mancard" bs and replace it with "Faster Then Most"
[Re: 1980volare]
#2520270
07/10/18 11:06 PM
07/10/18 11:06 PM
polyspheric
New York
True - easier on the internal parts, and fewer of those annoying loud-noise-followed-by-fireball events.
Boffin Emeritus
[Re: Porter67]
#2520328
07/11/18 01:02 AM
07/11/18 01:02 AM
Posts: 4,672 Wichita
GY3
Wichita
Nice, give em hell. I find it a bit amusing at the lack of replies since you openly street race, (makes you a bad guy) and drive a unpopular mopar body style and alot of time just got grief over some of your posts here for it but you could hand most racers here there ass on the street or track. My street racer will only pull mid 9-s so I couldnt touch your ride and a turbo seems so much smoother then spray and although a bit of a ego hit knowing this I dont know anyone whos not silently thinking "This guy is doing good". Since you street race and the grief you have gotten in the past, id not expect you to post all the details of your build. I think the mods should remove the "Lost mancard" bs and replace it with "Faster Then Most" Oh no! People get butthurt over streetracing on here?!
[Re: Dave Hall]
#2520346
07/11/18 01:41 AM
07/11/18 01:41 AM
1980volare
Dayton, OH
All engine types can fail when you are trying to go like a bat outs hell. I would like to see some 10.5's under that thing! I’ve ran 28x10.5 stiffs on the street. I’m not a fan of how they drive, and I drive this thing a lot. They do hook way better on the street. 99% of the classes I run require a dot radial. Pulling timing on the street helps hook the radials tho. I’m hoping to test some 26” radials and see what those are all about.
[Re: GY3]
#2520525
07/11/18 02:19 PM
07/11/18 02:19 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
People get butthurt over streetracing on here?! People here get butthurt over pinion angle...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2520538
07/11/18 02:29 PM
07/11/18 02:29 PM
GY3
Wichita
People get butthurt over streetracing on here?! People here get butthurt over pinion angle... The question was infused and dripping with sarcasm.
[Re: 1980volare]
#2520966
07/12/18 11:45 AM
07/12/18 11:45 AM
polyspheric
New York
IME "goal" means "do you understand that twin 88mm on your 318 is rilly, like, stoopid?"
Boffin Emeritus
[Re: Porter67]
#2520982
07/12/18 12:39 PM
07/12/18 12:39 PM
Guitar Jones
I love to see a pic and the details of his combo, seems well thought out.
On a bit different note I posted a while back they were working on getting a cheap china kit under a grand and they have.
No one would ever expect mind blowing performance from this and really im not sure id run a fast car with it with all that could go wrong with the cheap spinners, but it would be a fun street setup to play with.
https://www.ebay.com/itm/MOPAR-SMALL-BLOCK-TT-DODGE-RT-1000HP-Twin-Turbo-KIT-318-340-360-5-2L-5-9L-MAGNUM/273062915239?hash=item3f93d16ca7:g:GoIAAOSw8RZafhUx Wow. That's a lot of stuff for that price. easy link
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 1980volare]
#2520983
07/12/18 12:44 PM
07/12/18 12:44 PM
Posts: 1,550 Michigan
Kiddart
it sure is. what is the highest base compression that you should start with? I am at 12 to 1. that's high but a new set of slugs and this kit I am in business for cheap.
Thank you Kiddart
[Re: Kiddart]
#2520986
07/12/18 12:48 PM
07/12/18 12:48 PM
Guitar Jones
it sure is. what is the highest base compression that you should start with? I am at 12 to 1. that's high but a new set of slugs and this kit I am in business for cheap. Depends, what's your goal. Sorry, couldn't help myself...
