Re: Reputable Hemi/Mopar Engine Builder in CA
[Re: Dduster]
#2518616
07/06/18 10:57 PM
07/06/18 10:57 PM
Posts: 34 nor cal
8pack
nor cal
You knocked the crankshaft into the thrust bearing of middle bearing when You installed the stick transmission, no end play. More names: Don Little, Westley, CA. Richard Nedbal (He's got an EFI 'bolt on' business but the name escapes Me. But He knows Hemi motors. Bob Mazzolini, Riverside, CA can help for directions. What exactly You going to do with the car/motor? You can spend a surpringly large amount of money on motor re-do if You're not careful. That is possible but I remember check everything twice when I was setting up the bellhousing but it will definitely need to be checked again. I emailed Richard but he said he has been out of the game to long and couldn't really point me in a good direction. I know anytime a hemi gets opened up it is very easy to empty out a person's wallet so I don't want to do this again. The car is setup as a toy aka to be able to do a lot of events but not really specialized. I plan on autocrossing, Virgina City hill climb, drag race it a little and cruise to a couple car and coffee events. The car is setup with a Control Freak front suspension, Winters quickchange rear with leaf springs, sliders, Caltracs, 285s in the front and 335 rears. The engine is has a Mike Jones custom ground solid lifter cam, lash caps, valve spring, Air Gap intake, twin Holley 750 Street Demon carbs, 3 quart oil accumulator and everything else is basically stock on the engine .
[Re: Stanton]
#2519057
07/08/18 01:17 AM
07/08/18 01:17 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
How about Richard Nedbal ?? That's me (Mopar_Rich). Been there done that ... LOL
[Re: 8pack]
#2519210
07/08/18 04:46 PM
07/08/18 04:46 PM
Posts: 20,786 A collage of whims
topside
A collage of whims
Plenty of good Norcal names already mentioned. Lambeck did my Hemi back in 1988, still going strong. We had a good relationship. HOWEVER, about 5 years later he did a race 340 for me that was full of errors & problems - oil pressure (clearances), valve notches machined THROUGH the domes, a mishmash of wrong & under-torqued bottom-end fasteners, etc - that we found on its post-mortem after it kicked a rod out on pass #3. Looked like it'd been built by his gardener, and he charged me $10,000. He said "tough sh*#", but offered me a T-shirt later at the track...
[Re: 8pack]
#2519372
07/09/18 12:52 AM
07/09/18 12:52 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By Stanton How about Richard Nedbal ??
That's me (Mopar_Rich). Been there done that ... LOL And wrote a book about it !!!
