Re: AlumaJ8 build
[Re: Defbob]
#2518331
07/06/18 11:02 AM
07/06/18 11:02 AM
Posts: 20,667 in a cattle trailer down by th...
Guitar Jones
I must say you do build some awesome stuff, nice work. You are very talented. I however cant imagine what you spend on that stuff or where you find things like a custom diff housing for a SD.
Re: AlumaJ8 build
[Re: Guitar Jones]
#2518347
07/06/18 11:44 AM
07/06/18 11:44 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I must say you do build some awesome stuff, nice work. You are very talented. I however cant imagine what you spend on that stuff or where you find things like a custom diff housing for a SD. There had been a suspicion on Pirate4x4 whether the Spicer Ultimate 60 balljoint setup was based on the production F350. Then Spicer released their “builder program” and you could buy the inner Cs loose. No one wanted to order a set and test it out. So I did. I measure everything and it matches the oem inner C. Takes the same balljoints, same spread and same inclination angle. By using the Superduty outers and not the standard kingpin stuff... I get to use 1550 u joints.
Re: AlumaJ8 build
[Re: redraptor]
#2538475
08/19/18 11:20 AM
08/19/18 11:20 AM
Defbob
Norwich CT USA
I picked up a pair of surplus Bussmann 3100 relay modules. And my tires showed up. Ended up going with 42" Pitbull Rockers since they had a 50% sale the other week. Compared the tires to Tom's wimpy 35s...
