Planning an axle flip,need to find parts. #2518124
07/05/18 08:01 PM
07/05/18 08:01 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
I am planning to do an axle flip on my truck, I would also like to replace the front and rear spring hangers while I'm doing it. The rear hangers are a little rusty and there's a spot of light or two through them, the front I have a relocated hanger bracket and want to go back to the stock Style. Does anyone know of a supplier for new replacement parts.
What is spring plates is the best option for this job.
Re: Planning an axle flip,need to find parts. [Re: moparborn] #2518254
07/06/18 12:50 AM
07/06/18 12:50 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
For the spring plates, I just welded a piece of flat plate to the old spring plate and transferred the holes. You also have to add a hole in the center for the locating pin.
Re: Planning an axle flip,need to find parts. [Re: moparborn] #2518499
07/06/18 05:28 PM
07/06/18 05:28 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
get ahold of Scratchinfortraction...he either knows, or has the parts and will help you out.
1981 Dodge D150 360 auto
Re: Planning an axle flip,need to find parts. [Re: moparborn] #2519041
07/08/18 12:38 AM
07/08/18 12:38 AM
Pa. U.S.A.
Pa. U.S.A.
I figured I could make use of the old spring plates if need be.
Perches are available,I need the spring mounts most of all,not sure where the original front mounts went to and the rear mounts are not in the best condition.
