A-body dash insulation help needed #2517673
07/04/18 09:20 PM
07/04/18 09:20 PM
Hershey, PA
73MagDuster Offline OP
Hershey, PA
I am putting my 1973 Duster back together that I bought in pieces. I have new under dash insulation but I don't know what pieces go where. I have a new jute pad and a package of die cut card board backed yellow pads from REM. I am hoping someone here can post some pictures of what goes where. Thanks in advance!
Re: A-body dash insulation help needed [Re: 73MagDuster] #2517900
07/05/18 12:47 PM
07/05/18 12:47 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
You have the dash frame out? Putting in that jute with the dash installed will not be easy as it glues to the bottom of the cowl area. I did not buy mine from REM, but from DMT, but should be cut to shape already. Wear a dust mask as that stuff is annoying to work with as you try to glue in place.
The fiberglass/cardboard pads should line up on the firewall, cardboard side facing out. If I recall the only tight spot is around the column brackets.
Re: A-body dash insulation help needed [Re: 73MagDuster] #2518015
07/05/18 03:44 PM
07/05/18 03:44 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Went through the same issue with my 72 Charger, I spent a lot of time doing Google searches, eventually found some.
Re: A-body dash insulation help needed [Re: 73MagDuster] #2518024
07/05/18 04:16 PM
07/05/18 04:16 PM
MA
steve70 Offline
steve70  Offline
MA
Here's a few pictures from my 71. Hope it helps
1970 Challenger T/A 4 speed
