Re: What is your 340 steady state highway gas mileage
[Re: ragtop]
#2514465
06/28/18 02:27 PM
06/28/18 02:27 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
1968 Barracuda, std 4 speed, 3.23, 225X70X14 tires. 71, 340, stock pistons, .480 lift camshaft, headers, lightly ported heads, 71 intake, 72 thermoquad. 22MPG US at 70MPH average. That was running B.C. to Alberta and down to Montana and back.
Sheldon
[Re: BDW]
#2514527
06/28/18 05:08 PM
06/28/18 05:08 PM
RUNCHARGER
The 22 was real with my 68 Cuda. I was very impressed. The car had no P.S. weighed 3200lbs, Barracuda is a pretty slick shape and the TQ and headers all contributed I think. I know how to tune car as well and it was properly jetted and had a proper advance curve in it. Also the manual trans doesn't slip like a tork convertor does. My Viper gets the same fuel mileage with it's 514 but uses all these tricks plus over gearing to achieve the same results.
Sheldon
[Re: RUNCHARGER]
#2514580
06/28/18 07:45 PM
06/28/18 07:45 PM
Posts: 4,748 Florida
BDW
The 22 was real with my 68 Cuda. I was very impressed. The car had no P.S. weighed 3200lbs, Barracuda is a pretty slick shape and the TQ and headers all contributed I think. I know how to tune car as well and it was properly jetted and had a proper advance curve in it. Also the manual trans doesn't slip like a tork convertor does. My Viper gets the same fuel mileage with it's 514 but uses all these tricks plus over gearing to achieve the same results. Sure that wasn't Km's? Don't want to be a d*ck, but with 14" tires and 70mph, what was the RPMs, 4000? I applaud you, must have had a super tune.
[Re: BDW]
#2514621
06/28/18 08:48 PM
06/28/18 08:48 PM
RUNCHARGER
Nope it wasn't kms. It was getting 26MPG but that was imperial gallons, converting to US gallons comes out to 22. It actually shocked me as I expected it to be more like 15 or 16 MPG US. The plugs were not white either. They were a light tan. I believe it was running on the primaries but you are dead on it was taching a lot higher than I would have thought would have made good MPG. I don't believe it could have made better MPG with a 2.76 either, so maybe it was a sweet spot for the camshaft. 2900RPM is what the calculator comes up with at 70MPH for 3.23 and 225X70X14.
Sheldon
[Re: BDW]
#2516891
07/03/18 02:45 PM
07/03/18 02:45 PM
RUNCHARGER
I'm the only guy on this thread that ran a TQ. It was a great carb but you won't find one in good shape these days. I imagine if I had run a square bore carb of some sort it would have cost fuel mileage dearly.
Sheldon
