4.7L v8 '03 Durango - intake or exhaust leak??
#251735
03/12/09 03:38 PM
03/12/09 03:38 PM
Posts: 1,329 NC
DCM71cuda
NC
Wife's 03 Durango has 4.7L. about 85k miles.
Developed what sounds like either an intake or exhaust leak on the passenger side. Becomes audible when accelerating, up a hill, etc.
Based on history of these motors, is one more likely than the other? At a quick glance I wasn't sure which it was....I'm thinking more likely exhaust leak either at the head/exhaust manifold or the exhaust manifold connection to the exhaust pipe.
Any thoughts, suggestions or experience of the same problem???
Thanks for any help.
Re: 4.7L v8 '03 Durango - intake or exhaust leak??
[Re: DCM71cuda]
#251737
03/12/09 07:44 PM
03/12/09 07:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
With the 4.7, chances are the exhaust manifold studs have loosened, or even fallen out!, causing the leak, seen a few 4.7's with this problem, esp. passenger side,.....If I recall, it's a 8mm thread, 40mm long, fully threaded
[Re: DCM71cuda]
#251738
03/12/09 09:27 PM
03/12/09 09:27 PM
Posts: 311 Mass. USA#1
hemi70
Mass. USA#1
i have also seen a few 4.7 exh. leaks due to broken manifold to head bolts (useually the rear most one or two on either side, most of the ones I have had were driver's side) There was always enough of the bolt/stud left that a stud remover tool would take it out. Manifold would have to be removed first of course. Gary.
[Re: 10sec440]
#251740
03/14/09 09:56 AM
03/14/09 09:56 AM
Posts: 1,329 NC
DCM71cuda
NC
OK...so it is the lower rear bolt [broken off] on the passenger side exhaust manifold. I guess i'll need to disconnect the manifold from the exhaust pipe, remove the manifold, get the broken bolt out. I've bought a few replacement bolts and a new gasket. Assuming I don't run into too many issues, how long a repair should this be? Is there a torque spec for those bolts??? Thanks again.
