Re: FITECH 6 pack [Re: larry4406] #2654522
05/12/19 10:06 AM
05/12/19 10:06 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
wow this post alive !
Re: FITECH 6 pack [Re: larry4406] #2654523
05/12/19 10:07 AM
05/12/19 10:07 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Originally Posted by larry4406
We like pictures...
Re: FITECH 6 pack [Re: sogtx] #2654609
05/12/19 01:10 PM
05/12/19 01:10 PM
moparx Offline
moparx  Offline
july [new] issue of hot rod magazine. page 50, has an installation article, 440 engine, lots of pics there.
beer
Re: FITECH 6 pack [Re: moparx] #3088725
10/24/22 04:04 AM
10/24/22 04:04 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Any First hand experience yet ?
Re: FITECH 6 pack [Re: sogtx] #3088726
10/24/22 04:59 AM
10/24/22 04:59 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I was reading recently about a shop that removed all the Fitech electronics and injectors and ran them with Fast electronics and someone elses injectors. After that, they said they ran very well.
Re: FITECH 6 pack [Re: jbc426] #3088795
10/24/22 11:09 AM
10/24/22 11:09 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Not surprising.
I have a neighbor with FiTech stuff on his El Camino build. I should say "had". He took it all off and replaced with a carb after all of his issues.
'63 Dodge 330
11.19 @ 121 mph
Re: FITECH 6 pack [Re: Lee446] #3088801
10/24/22 11:29 AM
10/24/22 11:29 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by Lee446
Thats interesting, fits square bore or spreadbore manifolds. Never seen a "spreadbore" 2300 two bbl. Go figure!
LMAO up
Re: FITECH 6 pack [Re: GY3] #3088807
10/24/22 12:07 PM
10/24/22 12:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not surprising.
We've installed a few a couple of years back and had less issues that we did with a Sniper / MSD system. the MSD was integrated with the sniper controller to allow one to electronically control the timing. After many talks with holley's tech's, we went back to a conventional MSD distributor and the issues disappeared whistling
I have heard of others having issues with the FI systems in the last couple of years so shruggy
Another thing to think about is support down the road. had a customer that bought an early TPI $$$$ system from holley many years back. due to some family health issues the project was put on hold. It wound up here as the shop that started is was belly up. When we called holley for support they said everyone involved with that system was no longer with the company and no one technically knew anything about it, However they did offer to sell us their current version down rolleyes flame
If it's not a factory set up i always ask myself is the "potential" gain worth the $$ twocents
Re: FITECH 6 pack [Re: TJP] #3088835
10/24/22 01:36 PM
10/24/22 01:36 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I like the system I have on my car. F&B Throttle Bodies. https://www.fbthrottlebodies.com/6-pack/ and a FAST ECU Controller https://www.fuelairspark.com/efi-systems/xfi-fuel-injection-systems.html
I have run this system for over ten year, with no major issues. The only thing I have had to do is, tighten the bolts on the plate to manifold, air leaks, and file the throttle blades a little bit to keep them from sticking, aluminum to brass cool at different rates, so when it cold down the throttle blades stuck a little.
No it was not cheap but it works great!
My Monster are real!
Living within your means makes life pretty easy.
Re: FITECH 6 pack [Re: 67vertman] #3098144
11/29/22 04:42 PM
11/29/22 04:42 PM
Ormond Beach, FL
71STROKERFISH Offline
Ormond Beach, FL
I Bought the 600hp, 4bbl version of the Fitechefi.com in 2016 used from a chivy guy, ran it for about a year and a half, then saw the 6bbl unit at SEMA in Oct 2017.
For the record, this was installed on my 1971 Plymouth Barracuda, 414ci/727. It was available for order in Feb 2018. I ordered mine and it went back order with Jegs for 7 months! Jegs was awesome as I was very patient. They regularly gave me updates as I requested them along with discounts on the already 1800+ spent. They have gone up in price since. Either was, the unit was finally installed on a Modman intake. I could not find a small block used, new or original intake for the life of me, until I installed the Modman. Imagaine that right.
Either way. There were a few hurdles to get this unit installed to include the obvious, intake, linkage that needed to be purchased separately from Fitech, fuel line/hose and get it running. I'll say, at the end of the day, I am very satisfied with this setup. Fitechefi.com and I have a pretty decent relationship since I've been dealing wit them for quite sometime now.
Remember, we are all old school carb guys and these new EFI systems are like out OBD 1 autos....I still have a 1994 Grand Cherokee that I've owned since 1997, 240k and it runs like a top...just like my Fitechefi.com unit.
#1 tip, make sure your engine is clean n healthy before installing EFI. The EFI will find the issues.
#2 tip, isolate your crank trigger wire
#3 tip, start with new plugs/wires
#4 tip, Get a true 12v source via the battery. Our Mopar engineers really don't allow us to get this via the fuse box etc. Believe me, I've tried.
#5 tip, be patient and believe this will work.
My overall opinion is this a reliable system. I run it on a 414ci stroker small block I built in 2000. This system when 1st installed allow me to take a 9.5hr road trip from OKC to Red River, NM and back. I lost an intake manifold gasket on the way back, but the unit with O2 sensing did it's job and got me all the way home. I think if this was a carb, I would have been on the side of the road.
Either way, a few more items of interest to my Mopar brethren. I run the Fitech inline fuel pump. I don't recommend this and have 100% intent to swap it out for a Holley stock mount with float pump. Just check out Holley's website for this. If you can remove your float switch, you can install this pump. This is a drop in unit that I plan to install on both of my running Barracudas.
Outside of that, give me a shout, 4055966513 or message me with questions.
-Doug
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: FITECH 6 pack [Re: 71STROKERFISH] #3098220
11/29/22 10:16 PM
11/29/22 10:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Fixed it for ya, easier on the eyes wink beer
Re: FITECH 6 pack [Re: 71STROKERFISH] #3098222
11/29/22 10:19 PM
11/29/22 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
does the system require a return line (fuel) ?
maybe a pic of the other side ? beer
Re: FITECH 6 pack [Re: TJP] #3098301
11/30/22 09:45 AM
11/30/22 09:45 AM
Ormond Beach, FL
Ormond Beach, FL
Depends on the system you choose. My inline pump does require a return line. The stock fuel line is used for this. Other kits..their Command fuel system and the intake pump does not. Visit FITECHEFI.COM for specifics.
Don't be skeered to swap to EFI, I made the jump and it's worth it. Pulling a 6bbl air cleaner on and off to adjust floats and mixture screws is no longer in my list of things to do. Adjust the AFR, pump shot etc on the fly in the car! Giggity!!
-dc
2018 Jeep Trackhawk
Re: FITECH 6 pack [Re: TJP] #3098302
11/30/22 09:45 AM
11/30/22 09:45 AM
Ormond Beach, FL
Ormond Beach, FL
Thanks!!
-dc
2018 Jeep Trackhawk
Re: FITECH 6 pack [Re: TJP] #3098304
11/30/22 09:49 AM
11/30/22 09:49 AM
Ormond Beach, FL
Ormond Beach, FL
In the picture above, I did have to modify my 4bbl throttle bracket to make the Lokar stuff work from my 4bbl unit!
Additionally, if you use a small bock modman intake, you will have to do a little grinding to make the front throttle body clear the intake manifold. I ground the intake and part of the front sensor.....I think it's the Map sensor...it's been a while...
Fitech has the throttle linage, but the bracket I used was my old one as stated above.
-dc
2018 Jeep Trackhawk
Re: FITECH 6 pack [Re: 71STROKERFISH] #3098367
11/30/22 01:07 PM
11/30/22 01:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
might look into it later when time permits. Wonder what a set of 4782-83 series Holleys are worth in pristine condition ? shruggy
