Re: When is an "improved" Harmonic Balancer required?
[Re: gzig5]
#2517109
07/03/18 06:12 PM
07/03/18 06:12 PM
Posts: 4,457 Washington
madscientist
Washington
I think an aftermarket dampener should be used always. They are inexpensive enough to use one every time.
[Re: gzig5]
#2517130
07/03/18 06:45 PM
07/03/18 06:45 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rulebook says anything quicker than 10.99. I would say anything spinning over 5k or so. Or if it's a dry rotted 50 year old OE piece. Common sense should guide the decision.
[Re: gzig5]
#2517384
07/04/18 11:51 AM
07/04/18 11:51 AM
Posts: 4,206 New York
polyspheric
New York
The /6, like all L6 engines, has a torsional twist problem due to crank length (unlike V6, V8) and should use a quality damper. Please note that when the ring separates from the hub it's toast, as on all dampers. The SEMA damper standard (S.F.I. 18-1) does not rate a damper’s effectiveness, or certify that it works at all (let alone on a specific engine) - only that it fit the designated engine, and didn’t explode during the test. Their interest is limited to safety and qualify control, not specific engineering results.
Boffin Emeritus
[Re: gzig5]
#2517418
07/04/18 12:51 PM
07/04/18 12:51 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
IMO anytime someone is going through the expense of rebuild an engine should upgrade better than stock.Then the quality of the replacement is up for debate.
[Re: hemi-itis]
#2517424
07/04/18 01:00 PM
07/04/18 01:00 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The aftermarket damper rule was put into effect because of high winding CHEVY dampers flying off and hitting people. The stock mopar damper is BETTER than a lot of the cheaper aftermarket dampers that are out there. My Son and I both spun Summit brand Dampers and they both went on the scrap pile. All my engines except one now have ATI dampers on them. Todd at Compitition Wedge recomended the Powerbond damper and I have on on my Sons engine he is using now. So far, so good.
[Re: gzig5]
#2517530
07/04/18 03:43 PM
07/04/18 03:43 PM
polyspheric
New York
There are only a few RPM levels in which torsional forces are dangerous, largely based on the dimensions of the crankshaft. Power has nothing to do with it, except that it may push the RPM to a level beyond which the OEM damper doesn't work. Poster child: 289 Windsor low perf upgraded with 271 hp parts (especially cam and springs) but using the original (low RPM) damper: loosened bolts, damper shifted, crank breakage at front MB, etc. An OEM (bonded rubber) damper is almost always specific to not only a specific engine but specific stroke length and journal size. Aftermarket silicone, friction etc. can work on more frequency range and are more generic. Read more http://harmonicdampers.com/index.php?main_page=page&id=4&chapter=0
Boffin Emeritus
[Re: gzig5]
#2517560
07/04/18 04:36 PM
07/04/18 04:36 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've seen the results of stock Chevy stuff coming apart in the old days. The amount of damage they could do was impressive. Buddy had one come apart in a first gen Duece, sever a brake line and about lose the whole car. Personally I wouldn't use an OE type piece on anything but a stock/resto type engine that I want to look original and uses original front accessories.
[Re: gzig5]
#2517636
07/04/18 07:18 PM
07/04/18 07:18 PM
Posts: 43,159 Bend,OR USA
Cab_Burge
I've used a bunch of different balancers on both BB and SB Mopar V8 from cheap to all out race. I have a pair of used after market race SB balancer in my shop now, a ATI and a Fischer Racing fluid type, I'm hoping to use the ATI on a Hi Po pump gas 360 stroker motor converted to internal balanced No plans for the other one On your deal the Power Bond will probably meet all your needs
[Re: Cab_Burge]
#2517696
07/04/18 10:02 PM
07/04/18 10:02 PM
Posts: 4,672 Wichita
GY3
Wichita
I'd have to advise against using the 440Source one. Less than 4 years old and never seen over 6400 rpm.
[Re: GY3]
#2517747
07/04/18 11:25 PM
07/04/18 11:25 PM
madscientist
Washington
I'd have to advise against using the 440Source one. Less than 4 years old and never seen over 6400 rpm. What style of dampener is that? I can't tell if it's an elastomer or fluid style.
[Re: madscientist]
#2517783
07/05/18 01:37 AM
07/05/18 01:37 AM
GY3
Wichita
I'd have to advise against using the 440Source one. Less than 4 years old and never seen over 6400 rpm. What style of dampener is that? I can't tell if it's an elastomer or fluid style. Elastomer/Rubber. Outer ripped away from inner for some reason. Crickets from 440Source.
[Re: pittsburghracer]
#2517799
07/05/18 03:27 AM
07/05/18 03:27 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
The aftermarket damper rule was put into effect because of high winding CHEVY dampers flying off and hitting people. The stock mopar damper is BETTER than a lot of the cheaper aftermarket dampers that are out there. My Son and I both spun Summit brand Dampers and they both went on the scrap pile. All my engines except one now have ATI dampers on them. Todd at Compitition Wedge recommended the Powerbond damper and I have on on my Sons engine he is using now. So far, so good. The Powerbond Race looks like a good option. Something doesn't jive with the application data on the Summit site though. I select the 340 motor but they say it only goes back to 72, which is externally balanced. I have a 70 340 motor so I need the internally balanced one. But, the description of the part says it is internal balance. Something is not right here? There is no mention of external weights to add or if the pics are correct, holes to mount them. If I search by 1970 340, Powerbond is not an option that comes up. Same thing on the Powerbond website. Only for 1972 or newer PB1004SS, but shows as neutral weighted.... https://www.summitracing.com/parts/pbb-pb1004ss/overview/
[Re: polyspheric]
#2517810
07/05/18 06:44 AM
07/05/18 06:44 AM
Posts: 234 Brisvegas, Australia
Alchemi
There are only a few RPM levels in which torsional forces are dangerous, largely based on the dimensions of the crankshaft. Power has nothing to do with it, except that it may push the RPM to a level beyond which the OEM damper doesn't work. Poster child: 289 Windsor low perf upgraded with 271 hp parts (especially cam and springs) but using the original (low RPM) damper: loosened bolts, damper shifted, crank breakage at front MB, etc. An OEM (bonded rubber) damper is almost always specific to not only a specific engine but specific stroke length and journal size. Aftermarket silicone, friction etc. can work on more frequency range and are more generic. Read more http://harmonicdampers.com/index.php?main_page=page&id=4&chapter=0 These are the only dampeners on the market with an alloy inner and a heavy steel outer, which to me makes them the best on paper (think a undercut crank counterweight) Anything else on the market has a steel hub and alloy outer or is all alloy... $467 is out of my budget a tad though http://harmonicdampers.com/index.php?main_page=product_info&cPath=7_61&products_id=121
[Re: gzig5]
#2517818
07/05/18 08:00 AM
07/05/18 08:00 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The Powerbond Race looks like a good option. Something doesn't jive with the application data on the Summit site though. I select the 340 motor but they say it only goes back to 72, which is externally balanced. I have a 70 340 motor so I need the internally balanced one. But, the description of the part says it is internal balance. Something is not right here? There is no mention of external weights to add or if the pics are correct, holes to mount them. If I search by 1970 340, Powerbond is not an option that comes up. Same thing on the Powerbond website. Only for 1972 or newer PB1004SS, but shows as neutral weighted.... https://www.summitracing.com/parts/pbb-pb1004ss/overview/[/quote] Could this be because of the symmetrical/ non symmetrical pulley bolt holes? Not sure what year they changed that.
